PCV Valve....should I buy it?
Old Nov 4, 2004 | 05:47 PM
Juki5536's Avatar
Well, I'm gonna order a laundry list of stuff for my car, and a I've heard the part PCV valve tossed around here a couple of times. It only costs about $8, is it worth buying and changing? What does it do, and how hard is it? Thanks for the info.
Old Nov 4, 2004 | 05:49 PM
PKaiser's Avatar
dont buy it unless you have to
Old Nov 4, 2004 | 05:57 PM
tomservo291's Avatar
I just changed mine ... I was getting a consistent popping sound though and this turned out to be the culprit.
It's not worth changing unless yours is malfunctioning ... it's part of the "60k service" so they last a pretty long time I would guess
it's somewhat of a pain, you have to unbolt all the brackets ontop of the intake manifold and move some hoses just to get to it, and then yank of the 2" hose that is on the PCV valve and pray you can get it to flex enough to come off
some would say its easy, but mine was being a punk
Old Nov 4, 2004 | 06:02 PM
2 Da Max's Avatar
i have 74k miles withoug changin my pcv, will this affect anything?
Old Nov 4, 2004 | 06:05 PM
95BLKMAX's Avatar
Damn Tom it sounds like your PCV valve had something against you. Well I just cleaned mine up with brake parts cleaner. The reason they go bad over time is that carbon/oil builds up inside the valve overtime and eventually don't allow the valve to open (or to close, w/e the case is, it can't move). So i just pulled it out and stuck the spray needle inside the valve on both the in and out of it and sprayed until the valve inside moved freely (chake it and listen for it moving) and the fluid came out clear (instead of brownish-black like in the begining). Vuala, like new.
Old Nov 4, 2004 | 06:13 PM
95BLKMAX's Avatar
What the PCV valve does is that it recirculated the air that builds up inside the crankcase of the engine and vents it into the intake to be properly burnt. If it becomes clogged, you'll have crankcase vacuum related issues... what they are, i don't know(mechanics jump in), but I don't want to find out either lol.
It doesn't take more than 15 minutes from taking it out to it being back in your engine. Its cheap insurance.
Old Nov 4, 2004 | 06:51 PM
njmodi's Avatar
Do I get a tax break?
Originally Posted by 95BLKMAX
Vuala
Since I noticed this for the second time - I figured you like the word - its voila - enjoy!
Au Revoir
Old Nov 4, 2004 | 07:50 PM
95BLKMAX's Avatar
Au Revoir
LOL
Old Nov 4, 2004 | 07:52 PM
njmodi's Avatar
LOL
Thats the spirit!
Old Nov 4, 2004 | 11:30 PM
maxima98vspec's Avatar
WTF u talking about?? taking everything apart to get it it?!?! it was a 1 job changing it out. i just stuck a flat head in there and poped it out...i did it all at 60k and somewhere alonge thoes change out it imporved my gas milage by alot. and its only like a 5 $ part what are you guys whining about.
Old Nov 4, 2004 | 11:53 PM
vortechpower's Avatar
ive got 102000 and never changed it. It's not hard to do. yeah, quit your biatchn!
Old Nov 5, 2004 | 02:26 AM
mansurxk's Avatar
its beyond me what some of these guys are talkinga bout. it took me like 3 minutes to do it in the dark. y ou just unbolt the bracket that holes the hoses in that area so you get enough flex, then just yank the house and the pcv shuld pop right out....3 minutes....5 if you're a turtle.
Old Nov 5, 2004 | 08:33 AM
do you guys have like midget sized hands? the only way i could get to it was to remove everything from ontop of it and yank the hose off
my pinky wasnt small enough to get near that thing without moving **** outta the way ...
Old Nov 5, 2004 | 08:43 AM
sterlingmaxima's Avatar
the dealers around here never change them but i did it is cheap and preety easy to change plus i like new parts.
Old Nov 5, 2004 | 11:02 AM
SPiG's Avatar
SomePsychoGuy
I think it is supposed to be replaced like every 10k miles or so. It is really cheap and takes less than a minutes to change. I see no reason to not change it.
Old Nov 5, 2004 | 11:08 AM
RA030726's Avatar
I'm nutty for Nissans
ive got mine setup so it pops right out. I have an oil catch can hooked between it and the IM. catches all the extra blow by oil.
Old Nov 5, 2004 | 12:57 PM
Juki5536's Avatar
Ok thanks for the info. I'll just order it and....try... to read these directions given to change it
Old Nov 5, 2004 | 01:50 PM
goodhead's Avatar
when i did mine someone told me when you take the old one out if it doesnt make the rattlign sound its bad but then again since you got it out already to check mind as well change it
Old Nov 5, 2004 | 01:57 PM
philly96maxima's Avatar
Au Revoir
it's not spelled vulva ?
Old Nov 5, 2004 | 01:59 PM
MDeezy's Avatar
can you . . .
can intake cleaner do the job as well to clean out the PCV valve?
want to clean mine for better gas but dont want to buy new parts yet.
I think it was called carb choke something I bought at advanced auto parts to clean my intake when it gets dirty.
Old Nov 5, 2004 | 04:59 PM
QuickFast's Avatar
The PCV (Positive Crankcase Ventilation) valve is very important because it prevents the buildup of acid or water due to the condensation of the blow-by during compression. The acid and water can wear down and damage the crankshaft.
Old Nov 5, 2004 | 05:05 PM
mansurxk's Avatar
just buy a new one, its $3 at strauss discount auto, you might not clean it completely if you try it youreslf.
Old Nov 5, 2004 | 06:55 PM
DAVE Sz's Avatar
Hooooooonda.....
Damn, $8 for a PCV valve, is it made from super plastic and rubber? It costs $2-3 at most. Don't be stupid and use CARB cleaner on a maxima.
Mahmuth
Aug 16, 2024 08:23 PM
Apr 16, 2020 05:15 AM
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
