Coolant leak?
Old 11-06-2004, 08:39 AM
phathead's Avatar
Coolant leak?
hey i parked my car in the driveway last night and when i moved it this morning neon green fluid was all over the drive way. im not to engine smart but i think it is coolant. what do i need to do about this and is it serious?
the only recent change to my car is that i installed an amp and subwoofers, but i dont think that could cause this. well, new taillights too, but that cant have anything to do with it.
thank you
phathead is offline
Old 11-06-2004, 09:17 AM
96maxer's Avatar
Better check your bottom radiator hose or your water pump. Don't drive your Max until you find the cause of the leak. Alot cheaper to change a hose or water pump instead of a blown head gasket.
96maxer is offline
Old 11-06-2004, 09:25 AM
MDeezy's Avatar
check your coolant reserve and see the level of that.
check and see where exactly it is dripping from. My friend had the same problem and it was a crack in his radiator, had to put in a new one.
it might be a hole in a hose for your, if you cant find exactly where it is dripping from check all coolant lines and see if you see and holes in them.
MDeezy is offline
Old 11-06-2004, 09:40 AM
notsofun's Avatar
Yeah really check around the water pump, because when they are on there way out they havea thing called a weep valve which slowly drips fluid out...
notsofun is offline
litch
123
01-04-2024 07:01 PM
aw11power
10-10-2021 04:57 AM
Miket2006
03-01-2021 03:55 AM
foodmanry
09-24-2015 12:02 PM
Hdnseek
09-09-2015 05:55 AM
Quick Reply: Coolant leak?
