Part number for evap system pressure sensor?
i have code 0704 from ecu, did some trouble shooting and found the evap system pressure sensor is not working correctly, i need to order this part but i dont know the part number, can anyone help? thanx
Originally Posted by StrikerHA
haha alright, i tried that, but they said they cant order the part cuz it could be any number of sensors, does anyone know which one it is?
I believe when they told you "it could be any number of sensors", they meant that other components in the evap system can malfunction and cause the P0450 (0704) code. Other possibilities are: vent control valve stuck open or an open (or short) in the harness or connectors.
In your first post, you said you went through the diagnostic procedure and determined that the pressure sensor itself was the culprit. If you have not already done this, you can use a hand vacuum/pressure pump and a voltmeter to check the sensor directly.
mrc00l88
01-25-2024 01:14 PM
BassAddictJ
08-04-2015 11:38 AM
