EGR system
EGR system
A couple of months ago my MIL came on and I pulled code 0302...insufficient flow to the EGR valve. Actually the MIL came and went several times and finally went out and hasn't been back. But I know things can't be right and my car accelerates terribly. Not sure if it is associated but I'll start there knowing there is a possible problem.
When I was checking the EGR I felt the stem on the valve would not move. I also noticed warm air shooting out of a small pipe that seems to be disconnected and I have no idea where it connects to. It is located near the EGR valve and it pushes (versus vacuum) out warm air.
Actually I thought I had an exhaust leak because that's what is sounds like. I guess I found the source but it connects to something and I'm not sure what.
Anyone know?
Thanks!
Anyone know?
Thanks!
I had that code amonth long. Its basically caused by a blockage in your egr system. Meaning mostly its dirty. When you said you felt the stem on your egr, what do you mean by that? Where you reving the engine at the time. Its only going to move when the engine is under load/ doing work. A good way to check if its bad is to remove it. You'll push the flap up and before letting go place a finger over the top part of it covering the hole. If the flap doesn't move then your egr is good. Egr's go out but not that very often. You really need to check your BPT valve its right next to the EGR valve. It look like a 2" UFO. Those things get clogged way before the EGR ever does. Also check the hoses connected to it and make sure you clean them out before putting everything back together. PCV is also part of the EGR so check that to.
How to troubleshoot EGR problems.
Credit to Dave SZ.
http://img52.photobucket.com/albums/v158/evilBIGD/EGR/
Credit to Dave SZ.
Credit to Dave SZ.
Credit to Dave SZ.
Great link thanks!
