Front Clear Bumper Lense???
Old Nov 9, 2004 | 05:12 PM
browne's Avatar
can someone tell me how to install clear bumper lenses for my 98 maxima??? i tried browsing through the how to section but couldnt find it. i tried using a screwdriver to pry it out but im affraid i might break it. what is the proper way since i dont see any screws to take it out. thanks.
Old Nov 9, 2004 | 05:17 PM
99 SE-L
The big piece is held on by a phillips screw the little piece pry it off wiht a flathead screwdriver dont be afraid and from there i would imagine you would know...
Old Nov 9, 2004 | 05:22 PM
ManualMaxima's Avatar
5th Gen till she dies!
dude you will not breake it...it will defiantly come off before it even comes close to breaking. just stick a flat head and pry off the smaller one, and then loosed the screw and take the big one off. it is easy!
Old Nov 9, 2004 | 05:24 PM
99 SE-L
browne's Avatar
where should i pry it off from? in the middle (between the big piece and small piece) or from the end of the small piece??? thanks.
Old Nov 9, 2004 | 05:25 PM
Igobuk's Avatar
Yeah, just stick a flathead screwdriver in there straight into the gap... so basically the screwdriver is pointed straight towards the rear of the car. Then gently pry outward. If you're face to face with the car (as you should be) pry to the right to get the driver side to pop out and to the left for the passenger side. Just keep prying, it WILL pop out.
The only thing you have to be careful about is to not use the adjacent lense for too much leverage, you may chip it.
If you can find a wide enough flathead, you can stick it in there and just twist in either direction... that'll pop it out too.
Once you have them off you'll see the screw that holds the other one, etc. After that you'll have it.
99 SE-L
Between the big piece and the middle piece
Old Nov 9, 2004 | 05:30 PM
browne's Avatar
thanks for the help guys.
Old Nov 9, 2004 | 05:45 PM
yhtan76's Avatar
if you have the manual book, it shows you how to pry it out.
Old Nov 10, 2004 | 04:14 AM
browne's Avatar
alright, i was able to pry it out and change the lenses but i notice the small lenses doesnt stay as tight as the stocks. seems a bit loose. does anyone else have this problem??? did i get some bad lenses? thanks.
Old Nov 10, 2004 | 04:17 AM
kbmaxima's Avatar
doesnt fit as great as u want them to.. Get some 3M double sided tape. the white foamy part and try to find somewhere to stick it so it'll wedge in. I installed mine and they're perfectly flush to the bumper some people have complained that one side sticks out more than the other. Long story short, it's aftermarket and it won't be 'perfect'.
Old Nov 10, 2004 | 04:30 AM
browne's Avatar
you read my mind. i was planning on getting some double sided tapes and make it fit tighter. just wondering if others have this problem.
Old Nov 10, 2004 | 07:32 AM
i put a clear peice of tape over the crack between the larger lense and smaller lense. then they won't ever come out if you are driving. putting bumper lenses in is not that hard just try to fix it....i mean it is a light housing...what bad can happen?
Old Nov 10, 2004 | 09:47 AM
nitroz's Avatar
You did use the stock screws, correct?
If not use those. If you did make sure you adjust the so that they fit in the plastic connector.
Old Nov 10, 2004 | 02:39 PM
browne's Avatar
yeah, i used the stock screws and plastic connectors but it seems like the small piece is a bit smaller then the stock ones. its definately a loose fit as i can slightly move it up and down.
Old Nov 11, 2004 | 08:43 AM
chipobrien's Avatar
Thanks for the tips; I just did my diamond cuts that have been sitting in the basement for 2+ years, LOL. Boy, won't my son be surprised. I had read some instructions that said to go in through the plastic in the wheel well, "break a plastic thingie" and install; that's when they went into the basement. The thread to the install that I quoted is now gone, thankfully.
The smaller lense on the right side is a little loose, will get some 3M and fix today. Total install was less than 15 minutes. I now have to get used to the look, not sure that I like it as much as the ones I saw on a 99 Max on the GSP in May, but time will tell. I'm using yellow 3156 bulb and smaller yellow bulb in side markers, will look for upgrades online. Any suggestions?
Thanks again.
Old Nov 11, 2004 | 09:21 AM
BaiCheSE's Avatar
just a quick note:
when you buy the diamond clear lens, look on the back. you will see a rubber tube shaped like the letter "U"
look at your stock lens. On the back you will see a similar rubber hose, but it has a breathing filter on it. I switched it onto the Diamond clean lens. I assume this helps any vapor dissipate from the lens.
AcuraLegend
Oct 17, 2016 08:47 PM
AcuraLegend
Sep 22, 2015 04:22 PM
cash94
Aug 27, 2015 08:09 AM
Samedi
Aug 12, 2015 01:54 AM
