Front & Rear Disc brakes change
Old Nov 10, 2004 | 11:52 AM
dallas0593's Avatar
Ok guys, i just did my 1st job on my new car. I have a 1995 GLE w/abs. I followed the directions from motorvate and the Haynes manual [which i really didn't need because of motorvate]. The instructions were dead on. Took me 4 hrs and a whole hour on the drivers rear because the the little slide piston like thing was rusted in place, that was a biotch but after sprayin with wd-40 and channel locks i got it to break loose and all went easy after that. No more squealing and the brakes stop on a dime. Funny thing i found was that whoever changed the brakes last didn't have the correct rear pads for the car SO THEY CUT THEM TO FIT! . Just wanted to say thanx to these boards for the stickies and articles that i found on "how to replace your brakes" without these boards i probably would have never even attempted it, even though they wound up being very easy. Thanx maxima.org!
Old Nov 10, 2004 | 12:29 PM
twiggy144's Avatar
Self-rewarding, isn'it?
Old Nov 10, 2004 | 12:35 PM
Jeff92se's Avatar
I'm needing a caw
Sir. With 66 total posts as of today, you have more logical sense than 99% of most new members here and 75% of all the other members.
I commend you for your research and post skills. If only others would follow your lead. I salute you!
Old Nov 10, 2004 | 12:40 PM
NmexMAX's Avatar
dot dot dot ...
I agree, better to read a success story rather than a " how do you do this........." thread.
Hopefully others will follow your lead.
Old Nov 10, 2004 | 12:59 PM
Whitemax's Avatar
Disco Biscuit
I hope your brake job fails........
just kidding. Congrats on a job well done. I've owned mine now for 6 years, and still haven't tackled the brakes yet....
Old Nov 10, 2004 | 01:45 PM
I30tMikeD's Avatar
I nominate him as newbie of the year.
Old Nov 10, 2004 | 02:46 PM
njmodi's Avatar
Do I get a tax break?
Old Nov 10, 2004 | 03:32 PM
dallas0593's Avatar
Thanx for the kind words guys, yes the job was very "self re-warding". I am extemely happy i found this site when i bought my maxima. There are tons of people on here with huge amounts of knowledge about Maxima's , hope to be pickin your brains when it comes to my future projects. Thanx again guys!
Old Nov 10, 2004 | 03:34 PM
dallas0593's Avatar
LMAO!
Old Nov 24, 2004 | 05:58 AM
dallas0593's Avatar
Well seems that something is messed up. After about a week the sqealling came back. It happens whenever i am lightly pressing on the brakes. If i press hard the sqeal goes away, but it is really startin to annoy me. Now to my question. The fronts didn't have any shims and the rears were in pretty bad shape. But i had the wheels apart and no other transportation to the car parts store to buy a new kit, so i put the old ones on the rear and didn't put any on the front. Will this make them squeal like crazy when applying slight pressure? I am thinking this is the cause but want to pick your brains before i pull off all my wheels and replace the shims.
Old Nov 24, 2004 | 06:06 AM
A32Matt's Avatar
putting the old shims on will not cause a problem unless they are pretty beat up. The fronts are supposed to have shims on them which could cause a squealing noise if not put on or not put on properly. You might just want to get new shims for all of the brakes, or just for the fronts and make sure you use some kind of brake lube and get all of the caliper-to-pad contact points. I used this 3M grease at work for brakes and it worked pretty well. It's in a small can with a brush and is a white/clear grease.
Old Nov 24, 2004 | 06:16 AM
dallas0593's Avatar
Yes the rears were pretty bad and i remember saying to myself "replace them" but i didn't want to put everything back together again to go to the store. And i did put a bunch of anti-squeak stuff on. Now i will have to do just that. Damn, that's what i get for being lazy!
Old Nov 26, 2004 | 04:00 PM
vahmed's Avatar
I had run into a similar problem with my honda once so this time with my max I took no chances and got the brake hardware kit from autozone since I was going to do my front pads/rotors on thanksgiving day.
Huttig2009
Sep 25, 2015 03:31 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
george__
Aug 18, 2015 07:06 PM
RealityCheck
Aug 5, 2015 06:18 AM
