Low Idle
Old Nov 12, 2004 | 10:33 AM
HarrisH's Avatar
Low Idle
I adjusted the idle screw a lot of times but my idle after coming to a stop still drops to like 550 600 sometimes even lower. I did a full tune up not to long ago but what gives why is it low?
Old Nov 12, 2004 | 10:39 AM
Kehops's Avatar
Could be you need a throttlebody cleanup. Mine would sit at 400 then creep back up to 700. I just cleaned the throttlebody and everything is back to normal.
Old Nov 12, 2004 | 10:40 AM
njmodi's Avatar
Do I get a tax break?
Sometimes the IACV gets dirty - clean this out while you clean out the TB.
Old Nov 12, 2004 | 11:28 AM
DAVE Sz's Avatar
Hooooooonda.....
Why would the TB affect idle? Did you disconnect the BROWN TPS connector before adjusting idle like you're supposed to?
Old Nov 12, 2004 | 11:30 AM
njmodi's Avatar
Would a TB that is sticking open affect idle speed? I thought it would.
Old Nov 12, 2004 | 11:36 AM
Kehops's Avatar
Maybe I just misread but from what he was saying, it sounded like it drops intermitently to 650-700, which is normal idle. If the idle is rough and RPMs fluctate, I would say it could related to TB.
Old Nov 12, 2004 | 11:45 AM
goodhead's Avatar
reset your ecu see if that helps, alsomake sure the CEL light is one when you turn it to the ON position, w/o starting the car, (this is normal)
Old Nov 12, 2004 | 08:36 PM
HarrisH's Avatar
You're supposed to adjust the black screw after you remove the BROWN TPS connector??? How do you know if your TPS is good or not...?
Old Nov 12, 2004 | 08:49 PM
njmodi's Avatar
Yes... that is the correct procedure.
Old Nov 12, 2004 | 08:51 PM
HarrisH's Avatar
While the car is running or off?
Old Nov 15, 2004 | 06:49 AM
njmodi's Avatar
http://home.earthlink.net/~maxfaq - look under maintenance for how to adjust the idle speed - the entire procedure is outlined there.
TKHanson
Nov 24, 2018 01:39 AM
Unclejunebug
Apr 2, 2016 05:42 AM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
