Tokicos, help!
Old Nov 12, 2004 | 05:23 PM
1991tsi's Avatar
Tokicos, help!
The installation instructions for my rear illuminas explicitly say not to tigheten the top nut more than 49 ft-lbs to avoid damaging the adjustment mechanism. Question: is this before the spring is released (while still compressed and exerting no force) or after??
Also, should the upper seat be perfectly horizontal or slightly tilted with respect to the strut? Thanks in advance...
Old Nov 12, 2004 | 05:37 PM
njmaxseltd's Avatar
Tighten the nut until it's snug, don't crank it down. You can do that with the sping tension on or off. Then put the locking nut on top and give it a slight tug. The upper perch may be tilted slightly. Just put the shock assembly into the car and tighten up the 2 nuts on the mount. Be carefull not to over tighten them or you'll snap the studs right off. Just give them a nice snug.
EDIT: Make sure the studs on the mount are in line with the lower bolt hole on the shock. It will all line up in the car nicely if it's assembled that way.
Old Nov 12, 2004 | 05:44 PM
1991tsi's Avatar
wouldn't "snug" be different depending on whether the spring is compressed or not? how much thread should be showing above the nut... i have about an inch or more, does this sound ok?
Old Nov 12, 2004 | 06:10 PM
njmaxseltd's Avatar
You'll feel the nut stop turning when it's "snug". An inch or more thread showing sounds right.
Old Nov 12, 2004 | 06:53 PM
1991tsi's Avatar
got it, thanks for your help. now for the test drive...
Peter Paul
Jan 2, 2016 05:18 PM
MaxLvr21
Oct 17, 2015 12:11 PM
Stagnet04
Oct 11, 2015 08:16 PM
95Maxi
35
Sep 2, 2015 10:37 AM
