Radiator support-Bolt in or Weld in?[Pic]
Old Nov 15, 2004 | 09:16 AM
lunchbox's Avatar
I was just curious if anyone knew if this radiator support was something I could replace myself or if I'd have to have a shop do it? It looks as though I can, but looks can be deceiving. Thanks.
Old Nov 15, 2004 | 09:36 AM
dallas0593's Avatar
You look very confused standing there . I believe it is bolted on [not positive] but i don't think they weld that anywhere. I can check Haynes manual when i get home but that probably doesn't do you any good right now.
Old Nov 15, 2004 | 09:44 AM
MDeezy's Avatar
I belive that is bolted, I may need to replace mine, but I'm sure its bolted in, but you'll have to take just about the whole front off to get, that piece because everything is bolted to that.
just be prepaired to take off a lot of bolts and screws, keep it organized and it should go smoothly.
let me know if it turns out its welded, or if its is indeed bolted.
Old Nov 15, 2004 | 09:52 AM
vortechpower's Avatar
Im gonna say bolted. Maybe try taking fenders off
Old Nov 15, 2004 | 10:41 AM
lunchbox's Avatar
Nah, Thats my dad. I'm the cameraman.
I kind of figured that was the case. The Insurance guy is comming tomorrow to check it out and cut me a check. Then I'll start buying all the 97-99 stuff and some Cefiros. Thanks a lot for helping me out guys. When I get the car fixed, there will deffinatly be a nice donation for the .org.
Kevin.
Old Nov 15, 2004 | 10:53 AM
lunchbox's Avatar
I'll let you know in a couple of days.
Old Nov 15, 2004 | 12:56 PM
ny96max's Avatar
that is one entire piece going across the front end of the car... i believe its only bolted to the front end supports. If you can strip the car down and have only the radiator support assembly exposed you should be able to swap it out yourself and save some money. Aftermarket ones cost around $150 plus shipping and wont fit like OEM.
Ant
Old Nov 15, 2004 | 02:02 PM
lunchbox's Avatar
Ant
I'm gettin an OEM one from a junkyard, well...At least I'm gonna try.
Old Nov 15, 2004 | 03:16 PM
MDeezy's Avatar
me too
Old Nov 15, 2004 | 06:07 PM
lunchbox's Avatar
I just have to find a yard here in the sticks that has a maxima....That may be a task in itself.
Old Nov 15, 2004 | 08:19 PM
Broaner's Avatar
2060lbs and falling...
Looks like deer damage to me. That piece is definitely welded. Its part of the unibody. Sorry to go against the grain. I wondered the same thing when I was in an accident. I wanted to replace in myself but at the time I had no idea how to weld. The pieces you guys are getting out of junk yards are pieces that have been ground out.
Old Nov 15, 2004 | 09:51 PM
G20Flyer's Avatar
Sorry to give you bad news, but that thing is welded and riveted on. You'll have to take it to a shop to do and the frame may have to be aligned.
Old Nov 15, 2004 | 09:55 PM
lunchbox's Avatar
Well son of a *****...
Old Nov 15, 2004 | 10:38 PM
lunchbox's Avatar
http://cgi.ebay.com/ebaymotors/ws/eB...category=33645
hmmm
Old Nov 16, 2004 | 11:08 AM
Broaner's Avatar
TopElement, I thought the existing welds might be kinda flimsy. Do you think the chassis would be shored up if I ran a bead along all the contact points?
Old Nov 16, 2004 | 12:11 PM
Broaner's Avatar
My lower beam is very fxcked. I welded the engine crossmember to it because the support pulled the nuts through the sheet metal. Also, some of the spot welds along the top edge of the lower bar have broken. I'm removing my front end sometime this month to get at it. I think I'm gonna lay a bead all along the top seem. You think that would at least fix the problem if not increase the rigidity from stock?
Old Nov 16, 2004 | 01:22 PM
C MAX's Avatar
its welded and you need a frame machine when you take it off to align back the parts properly. i had to change mine twice due to accident not so easy job without experience.
Miket2006
Mar 1, 2021 03:55 AM
Apr 16, 2020 05:15 AM
NmexMAX
May 23, 2016 07:38 PM
BobTX10
Oct 7, 2015 08:43 AM
bigfrank
Oct 1, 2015 12:51 PM
