95 electrical problem-HELP!!!
One day, I go to lunch and everything is great. I get in the car at the end of the day to go home and the remote keyless entry doesn't work. I use the key in the lock and find that the following no longer work - a) electric door locks, b) electric windows, c) rear defogger, d) intermittent wipers (possibly unrelated?).
It sounds like a master fuse problem, but none show that they are melted.
Any ideas?
Any ideas?
Check your fuses again. There are fuses inside the car and inside the engine bay. Find the fuse that should be responsible for some of those accessories and swap them out with equivalent ones and see if that works.
Does the car drive properly other than the items you mentioned in your post?
Unclejunebug
04-02-2016 05:42 AM
HerpDerp1919
09-29-2015 02:02 PM
