Adjustable Versus Non Adjustable Shock/Struts?
Old Nov 16, 2004 | 08:37 PM
browne's Avatar
im planning on getting eibach pro springs but cant decide whether to get adjustable or non adjustable shocks. im not looking to be racing but just a sporty ride. theres obviously a price difference but is there a great difference in terms of performance??? thanks
Old Nov 16, 2004 | 08:46 PM
MilesA's Avatar
The main advantage with the adjustables for a street car is that you can tune your shocks to work well with your springs. Once you find a setting you think is optimal, you can leave them alone.
We are not talking about trying to make the Maxima a sports car, but tuning the ride/handling balance so the car feels more stable and well-planted in everyday enthusiastic driving. IMHO, the Illuminas or Konis are well worth the extra cost if you value a well-controlled ride.
Old Nov 16, 2004 | 08:52 PM
SmoothMax's Avatar
OG
There's a discussion about AGX's and Illuminas lurking around somewhere....
http://forums.maxima.org/showthread.php?t=353835
browne's Avatar
so is the non adjustable shocks equvalent to setting number 3 of the adjustable shocks. and then i have either 4 or 5 to upgrade too if i want it stiffer???
does anyone have non adjustable shocks with aftermarket springs and find it a sporty ride??? or does it need to be stiffer??? thanks.
Old Nov 17, 2004 | 12:47 AM
SPiG's Avatar
SomePsychoGuy
http://maxmods.dyndns.org/index.php?MaximaShocks
Originally Posted by maxmods.dyndns.org
So remember to not be cheap when selecting them. Stock or cheap shocks on aftermarket springs will actually handle worse a stock suspension, due to the rebounding and bottoming out from the shocks being unable to control the stiffer springs. Also running too low of a setting on adjustable shocks will also have the same effect.
Also remember when adjusting shocks, you adjust them for the spring, not for the ride. Too light and your car will rebound and bounce uncontrollably like a car with blown shocks. Too much and your car won't be able to recover from bumps as fast as it should. The ride will be generally bouncy at the lowest setting and will improve as you turn the shock up, and will start to get harsh again near the upper settings. That improved area in the adjustment is where you want to be. Recommended starting settings are shown for each shock, feel free to start from there, and adjust to your spring.
tarun900
19
Dec 20, 2021 06:57 PM
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
leatherneck
Sep 30, 2015 09:16 PM
