I checked MY ECU code
Old Nov 18, 2004 | 06:59 AM
97MAX_FORME's Avatar
I am getting a cylinder 2 misfire.. I 've been reading in the stickys for answers but since I am such a non car person yet. I don't quite understand..
Can someone anyone help? I've noticed my car has been running a little funny especially 1st, 2nd gear... Does that have anything to do with it?
Old Nov 18, 2004 | 07:22 AM
njmodi's Avatar
Do I get a tax break?
You probably have a bad ignition coil in cylinder 2.
1. Do you know if you have NGK plugs in there? If not, replace the plugs with NGKs
2. If you do have NGK plugs, then its most probably the cylinder 2 ignition coil. You can buy ignition coils online (jrnissanparts.com for example) for 50 bucks and put it in yourself in 10 mins.
Old Nov 18, 2004 | 07:35 AM
Thank you somuch njmodi
Old Nov 18, 2004 | 07:58 AM
OK I'm looking at NGK spark plugs and Now I see all kinds of choices.. obviously the more expensive the better but what's the difference and what's better?
Old Nov 18, 2004 | 08:07 AM
njmodi's Avatar
The original plugs recommended for your car are the NGK platinums - you can get a set of 6 for about 50-60 bucks (website mentioned above). You can also run NGK coppers (V-power) - that run 2-3 bucks a piece. They seem to work as well, but have to be replaced every 30k whereas the platinum plugs can be used for 60k. The part number for the two plugs is:
NGK platinums: PFR5G-11
NGK Copper: BKR5E-11
You can use either - just follow the replacement interval guidelines.
Old Nov 18, 2004 | 11:58 AM
cool thanx again
sctludwig
Sep 1, 2022 01:32 PM
mvm062
Nov 30, 2020 09:00 AM
ballerchris510
Sep 10, 2015 09:35 PM
mix master
Sep 4, 2015 05:50 PM
