4th gen coil spring question...
Old Nov 18, 2004 | 11:42 PM
vaiorian
I decided go back stock suspension('99). but there is some problem.
I dont know which one is right for driver and passinger side.
front oem spring have same part# so, they should be same.
But, rear springs are differant.(coil length & also part number. I guess tension too.) and they have some paint mark on the coil. i dont understand why rear springs have differant part#.
Does it mean someting?
please HELP me to figure it out!
Old Nov 18, 2004 | 11:48 PM
-MaxPayne-'s Avatar
before you get raped I would consider changing the color of the font. MIght get a better response for some help...
Old Nov 19, 2004 | 04:24 AM
njmaxseltd's Avatar
The springs are the same, left and right. Make the 3 dots look like a triangle. One dot on top, two on the bottom. Thats the correct position for the front coils. The rears will only mount on the shock one way. The lower coil is wound slightly smaller and sits on the rear shock nice and snug. If you put the spring in upside down, it wount sit perfectly on the shock perch.
Be carefull compressing the front springs, they are a PITA to compress and get back onto the strut. A wall mounted spring compressor makes the job much easier. If you know a mechanic or auto parts store that has one, you might want to let them put the front springs in. Just show them how everything lines up.
Good luck!
Old Nov 19, 2004 | 05:44 AM
mzmtg's Avatar
Minister of Silly Walks
Bah, you dont need any fancy compressor. I just used some twine and a couple of wrenches:
Just kidding.
Old Nov 19, 2004 | 05:58 AM
Colossus's Avatar
I've got to do this job myself in a few days, put some new struts on. Anyone have a good place to buy spring compressors? Sears? Lowes? Home Depot?
Old Nov 19, 2004 | 06:04 AM
mzmtg's Avatar
You can borrow them from AutoZone through their loaner tool system.
Old Nov 19, 2004 | 07:21 AM
s0ber's Avatar
Just kidding.
lmao, thats awesome...
Yeah autozone loans them out for like $35 I think.
They give u a good workout :x
Old Nov 19, 2004 | 08:38 AM
MaximaSE96's Avatar
Maxima Owner
autozone.....i think i was charged 40 but u get full refund when u return the tool...
Old Nov 19, 2004 | 09:57 AM
njmaxseltd's Avatar
I hope nobody takes that strut picture seriously.
Matt93SE
May 24, 2019 02:58 PM
Maxima_Joe
Nov 25, 2015 08:19 AM
Finkle
Sep 27, 2015 09:53 PM
Dasmith
Aug 25, 2015 10:15 PM
