HELP!!! How to remove shift nob on 1998 maxima
Old Nov 21, 2004 | 11:49 AM
RSPSupraTT's Avatar
HELP!!! How to remove shift *** on 1998 maxima
Does anyone know how this is done? It is a manual and when I try to twist it off, only the leather is going with me.
Old Nov 21, 2004 | 11:55 AM
Terran's Avatar
It twists off. Mines a '95 and just came off. If you don't mind ruining it you could use a set of visegrips. It may help to try heating it up a bit with a hairdryer or heatgun.
Old Nov 21, 2004 | 02:04 PM
vortechpower's Avatar
like he said. get some vicegrips. clamp down on it and twist.
Old Nov 21, 2004 | 02:21 PM
acj's Avatar
acj
If you want to keep your old shift ****, I don't recommend the vice grip method. I just used both hands and it finally broke loose. It took a few minutes, but it did work...and I still have the old ****.
Old Nov 21, 2004 | 02:43 PM
Terran's Avatar
yeah, like I said definitely only use the visegrips if you don't mind trashing the stock ****.
Old Nov 21, 2004 | 06:50 PM
kraimer21's Avatar
the visegrip method is by far the best and if you want to preserve your old ****, wrap 2-3 layers of cloth (terry cloth is the best) around the **** then use visegrips, thats what i did and it works beautifuly
Old Nov 22, 2004 | 11:15 AM
Vad3K's Avatar
grab with both hands very tightly and twist as hard as you can. mine came off this way after like 5 minutes.
Old Nov 22, 2004 | 11:33 AM
maximum810's Avatar
You could use the vice grips and some sort of cushion...like a rag or something if you don't want to damage the ****.
Lakersallday24
Nov 7, 2024 07:31 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
Trin1j23
Aug 12, 2015 08:31 PM
13Maximasv
Aug 7, 2015 10:56 AM
