1998 GXE Headlight Adjustment
Old Nov 23, 2004 | 09:22 AM
brd98maxima's Avatar
Car has been lowered and now my headlights need to be adjusted higher. I found the long rod coming out of the back of the light but could not turn it. Please advise on what is required to adjust those stinking lights.
Old Nov 23, 2004 | 10:03 AM
felix's Avatar
Sittin' On Chrome
i have the same problem. although mine did turn, nothing happend. i figured they're already as high as they go. sorry to be no help.
Old Nov 23, 2004 | 10:04 AM
cardana24's Avatar
Blown
it sounds like you what you tried to turn is the headlight adjustment....its a rod coming out of the back of the housing, with a little '****' on the end.....did you try turning it both ways?
Old Nov 23, 2004 | 10:07 AM
Conrad283's Avatar
I need a truck
I think it's an 8mm socket. Take out the corner light and you'll see it.
Go to a flat parking lot with a high wall and turn the **** with the 8mm socket until it's at the level you want.
Old Nov 23, 2004 | 10:18 AM
I did turn the passenger side but part of the **** broke off. I will try the 8mm wrench and see what happens. Thanks for the advice. Drive it in a MAX....
Old Nov 23, 2004 | 10:25 AM
Conrad283's Avatar
I need a truck
If the **** broke off, I'd suggest a vice grip that you can grip on the metal rod and turn it that way.
tarun900
19
Dec 20, 2021 06:57 PM
leatherneck
Sep 30, 2015 09:16 PM
Noela
Sep 26, 2015 08:22 AM
