Tranny Slipping!
Old Nov 23, 2004 | 11:58 AM
yeshivishmaxima's Avatar
Tranny Slipping!
HEY I GOT A 1999 MAX GXE AUTO.
I DON'T KNOW IF THE TRANNY IS SLIPPPING BUT I SEE THE RPM'S MOVING INSTANTLY FROM 2 TO 1 VERY FAST, RIGHT WHEN I LET GO OF GAS PEDAL. IS THERE A EQUATION OF RPM-MPH WHEN THE TRANNY SHOULD SHIFT,
EX. AT 60 MPH MY RPM IS 2.
Old Nov 23, 2004 | 12:05 PM
NmexMAX's Avatar
dot dot dot ...
Mph = rpm x tire diameter/Gear ratio x 336
Rpm = mph x gear ratio x 336/Tire diameter
And your car is shifting, that's why it goes from 2k-1k like that.
Old Nov 23, 2004 | 12:09 PM
PKaiser's Avatar
y would his car shift up when he lets off the gas?
Old Nov 23, 2004 | 12:11 PM
NmexMAX's Avatar
dot dot dot ...
Because it's automatic, and that's what it is designed to do.
When wot, the car will go higher rpm because more power is demanded, when cruising along, the engine electronic control is designed to be fuel effecient, hence keeping rpm's at a minimal.
Old Nov 23, 2004 | 12:13 PM
What Is Normal Rpm For Every Speed?
Old Nov 23, 2004 | 12:34 PM
NmexMAX's Avatar
dot dot dot ...
I don't know exactly what you mean, nor why you want to use this information, but if you use the formulas, you should be alright.
Old Nov 23, 2004 | 01:29 PM
99 SE-L
I have the same problem , but i dont really think it is a problem...
Old Nov 23, 2004 | 01:33 PM
NmexMAX's Avatar
dot dot dot ...
I also have the same behavior, that's why I say there's no problem.
Old Nov 23, 2004 | 02:19 PM
philly96maxima's Avatar
There is nothing wrong,,trans is free wheeling when you let off the gas
Old Nov 23, 2004 | 04:47 PM
Andy13186's Avatar
Yea your tranny upshifting, helps you glide forward instead of slowing down quickly(engine brakeing). No prob at all...
Old Nov 23, 2004 | 05:16 PM
Ninos_Maxima's Avatar
be the change u want2C
Your tranny is not slipping, if it was it would feel as if you have no tq at all and you can actually feel the TCC Slipping, (I think its called the TCC Correct me if Im wrong) My tranny is slipping, I dont think yours is from what you described, its just doind what its supposed to do, hense that name of auto trannys, little dumb machine
MaxStock
Dec 5, 2016 05:19 PM
fx4five
Oct 18, 2015 06:57 PM
fx4five
Oct 1, 2015 04:58 AM
pktaske
Sep 4, 2015 08:40 AM
Lowered_a33
Sep 1, 2015 07:49 PM
