installing rear springs? painting cars?
Old Nov 23, 2004 | 08:36 PM
joosdawg's Avatar
ok two questions for anybody that knows. 1. im installing some springs on turkey day and found on here a how-to for the front suspension and im assuming the back is the same with maybe a couple bolts inside the trunk lining? i just would like to see some pics of somone that has done a rear suspension job. ive done front before but havent looked at rear so just need to varify, is it eisier than front or no? and now painting...im painting a project car and need to know what i can use to sand off all the exsisting paint easiest, i know theres a chemical that eats paint off in like 5 seconds which is awsome but i think its illegal unless your a lisanced shop or somthing. so could i just use a power sander of some sort? also does anyone have any brand of primer that they like best or clear? i am just going to get some dupli-color primer and clear and go to a custom paint shop around here and get a custom color mixed up so i can spray it. -Ryan
Old Nov 24, 2004 | 04:24 AM
joosdawg's Avatar
anyone got instructions on a site or tips for me?
Old Nov 24, 2004 | 04:38 AM
ilacuss's Avatar
instructions can be fouund here http://www.vqpower.com/v2/modules.ph...howpage&pid=69
this are the ones I used when I put on my H&R's about a month ago. Everything was pretty easy ....no problems.
There is something called airplane stripper that should remove most paint.
Old Nov 24, 2004 | 05:18 AM
mzmtg's Avatar
Minister of Silly Walks
You dont need to totally remove the old paint. Sand it down and prime the spots that need it and you're ready to go.
Old Nov 24, 2004 | 07:04 AM
chuckie311's Avatar
they back is so easy 3 bolt. 2 in the trunk and one on the bottom. its not hard at all.i would start with the front first though. they were the toughest for me.especially to break them damn bolts loose. i broke a wrench trying to break a bolt loose
Lakersallday24
Jun 16, 2019 01:35 AM
Huttig2009
Sep 25, 2015 03:31 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
Greenmaxspeed
Aug 8, 2015 12:39 PM
laparka66
Aug 6, 2015 09:36 AM
