leaking coolant..please help
Old Nov 25, 2004 | 05:11 PM
maxspeed96's Avatar
im leaking coolant from between my oil pan and air condion compressor on my '96. i cant see far enough up between them to see where the leak is from since theyre so close together. i first thought my water pump was going out, but i dont think it would be leaking from there if it was. any suggestions before i start tearing things apart? much help appreciated.
Old Nov 25, 2004 | 05:13 PM
HarrisH's Avatar
Lower radiator hose...?
Old Nov 25, 2004 | 05:14 PM
maxspeed96's Avatar
all my hoses r fine
Old Nov 25, 2004 | 08:02 PM
macinmaxima95's Avatar
I had the same problem a while back and i had takin it to a radiator specialist because i had thought that it was my water pump. And it was... they replaced it and it stopped the leak. So you might want to consider taking it in or worse comes to worse do it yourself...but i have to wish you luck cuz thats the only job that i didnt even want the hassle of doin.
Old Nov 27, 2004 | 10:56 PM
maxspeed96's Avatar
Thanx alot macinmaxima95 I hope this is the case, but I dont get why it would be leaking from between the oil pan and air cond. pump
Old Nov 28, 2004 | 02:57 PM
I didnt get that either. However, when they replaced the water pump it fixed the leak so i dont know. I kinda stopped trying to figure it out and just let it go. Goodluck bro
Old Nov 28, 2004 | 02:59 PM
Ant96GLE's Avatar
Its your water pump... when the water pump is starting to go bad it has a weep hole it lets coolant flow out of... enjoy cuz thats one hell of a job.
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
Mar 12, 2020 12:06 AM
JoshG
51
Sep 21, 2015 10:41 PM
followthadollar
Sep 17, 2015 06:31 PM
