lack of power
Old Nov 26, 2004 | 07:46 PM
maximaryda2nv's Avatar
lack of power
car doesnt go over 80mph and when running doesnt rev more than 3000rpm what could it be i unplugged the boost sensor and doesnt do anything and the brown plug on the throttle position sensor and nothing. what do you guys think it could be please let me know
Old Nov 26, 2004 | 07:50 PM
99 SE-L
dosent rev over 3k rpm's possibly tranny problems
Old Nov 26, 2004 | 07:52 PM
SonicDust187's Avatar
Im like 90% sure you may need a new maf.
Old Nov 26, 2004 | 07:54 PM
when its on neutral it only revs up to 5000rpm
Old Nov 26, 2004 | 07:58 PM
the car is a complete cow a toyota tercel smokes it
Old Nov 26, 2004 | 07:59 PM
Terran's Avatar
I thought a bad MAF limited to 2000 RPM?
You should check for codes too. Maybe you'll get lucky and your car already knows what's wrong. http://vbxmaxima.8m.com/ecu.html
Old Nov 26, 2004 | 08:01 PM
99 SE-L
Does the car jerk? mayb your coil pack is going out
Old Nov 26, 2004 | 08:02 PM
GodFather's Avatar
Made in Taiwan
MAF sensor problem, if not, tranny big timer!!! bring it to mechanics.
Old Nov 26, 2004 | 08:05 PM
the jerks alot
Old Nov 26, 2004 | 08:07 PM
99 SE-L
Coil pack 99% dont drive car for long check for codes my freind had it car was jerking liek crazy couldint even drive checked codes said cylinder 5 misfire needed to get a new ignition coil $80
Old Nov 26, 2004 | 08:09 PM
no error codes came up when connecting to computer then we disconnected the IAT sensor and the computer read that so we know its working
Old Nov 26, 2004 | 08:12 PM
99 SE-L
I wouldint do it that way but if that read correct then im out of ideas..
Old Nov 27, 2004 | 03:16 PM
luga982's Avatar
its definitely your coil packs.
they have gone bad playa
you are gonna have to change them very soon, else, the car will not start when the problem becomes major.
Old Nov 28, 2004 | 03:09 PM
could it be a vaccum leak or clogged up cat
Old Nov 28, 2004 | 05:49 PM
anyone can help me
gigabyte
Jan 6, 2017 06:05 PM
maxinout93
Oct 31, 2015 02:04 AM
leatherneck
Sep 30, 2015 09:16 PM
