Pinstripe removal
Old Nov 27, 2004 | 11:03 AM
oTranscendental's Avatar
Pinstripe removal
There's got to be an easier way.
My pinstipes are old and cracked. They are impossible to remove. Using a credit card is not working.
Would heating them up with a hairdryer or heatgun help? Keep in mind they are really weathered.
Old Nov 27, 2004 | 11:05 AM
sharkulator's Avatar
I didnt use anthing, just washed my car dried it, detailed it and parked in the Texas sun. I have a black car so the pin stripes came right off. Use a hair dryer.
Old Nov 27, 2004 | 11:34 AM
z32drifter's Avatar
go to the automotive paint supply store.... you want to buy an "eraser".... it is a round soft rubber tool..... you can put it in a die grinder or an electric drill...... it is made of very soft rubber like an eraser (hence the name) so it will not damage your paint... trust me it is the only way to go..... when your pin stripes are old and cracked.... you can peel them off by hand but it will take forever
Old Nov 27, 2004 | 11:38 AM
happyricefob's Avatar
V^___^V
i did mine over the summer, it was like 100+ degree. i used hair dryer and peeled it off with my fingernails within 20 minutes....
Old Nov 27, 2004 | 01:09 PM
Ninos_Maxima's Avatar
be the change u want2C
Me and my friend did it to his old 240 in 60 degree weather, but we had like 3 hairdryers, burnt out fingers a couple times, My freind got frustrated and took a razor to the metal, I hit him, but yeah we used our finger nails and got a couple of blisters from all the rubbing because the lack of bug and tar off
Old Nov 27, 2004 | 01:20 PM
huyqvu's Avatar
3m rubber wheel and drill is easy and fast. dont apply pressure, just put the wheel up againt pin stripe and let it do its work. and becareful not to burn the paint, move it back and forth. when you're done step back and notice how your panels flow a lot nicer without the stripe.
Old Nov 27, 2004 | 06:38 PM
Terran's Avatar
Try with a heatgun/hairdryer first since that eraser makes kind of a mess (it all cleans off, just kind of a pain). I'd suggest mother's prewax cleaner to remove the glue and/or eraser mess. It may take some elbow grease, but it works great to get rid of the glue.
Old Nov 27, 2004 | 07:24 PM
A32Matt's Avatar
Mineral Spirts. NOT LAQUER OR PAINT THINNER! It'll take the pinstripes and adhesive right off and not the paint.
Old Nov 27, 2004 | 09:13 PM
kcryan's Avatar
hairdryer + googone or mabye lighter fluid??
Old Nov 27, 2004 | 11:39 PM
97WhtSE's Avatar
used heatgun with creditcard. Took all about 15 minutes to take off.
Old Nov 28, 2004 | 09:08 AM
Max Mutes's Avatar
Maybe your's are painted on like mine were and need to be wetsanded off.
Old Jan 24, 2005 | 06:43 AM
mingus2112's Avatar
discoloration?
anybody know if this will leave a lot of discoloration? since the paint has been exposed to the elements for a few years, i'd expect it to be a bit darker? I have a green mist 99 gle with gold pinstripes. I really want to remove them, but i'm afraid of it looking worse with a dark line then it does with the pinstripes!
-James
my03maxima
Jul 28, 2024 07:40 AM
doctorpullit
Mar 29, 2016 11:08 AM
RealityCheck
Oct 2, 2015 06:34 PM
jaydot901
Sep 29, 2015 01:18 PM
Max Nu-BE
Sep 28, 2015 10:25 AM
