Need Help ASAP !!!!
Old Nov 27, 2004 | 02:27 PM
5speeddemon's Avatar
Need Help ASAP !!!!
OK heres what happened I was putting in a new radio and my remote amp wire touched my power wire and i blow a fuse. My replaced it but now it want work and my clock stoped also. I have checked ever fuse under the dash ans they are all good. Need help with this hate riding around with no radio.
Old Nov 27, 2004 | 03:53 PM
DemonSpawn's Avatar
Have you checked the fuses under the hood? If they're all ok, you may want to just get out a multi-meter or test light and trace the wiring to see where the problem is.
On a second note ... you should really disconnect your negative battery terminal when working on the car.
Old Nov 28, 2004 | 02:34 PM
Would I check the big fuses? Or either tell me with one to check.
Old Nov 28, 2004 | 04:18 PM
DemonSpawn's Avatar
Check them all .. there's no telling what you shorted out when you crossed the wires. I don't have the wiring diagram handy, but from experience, your clock is most likely on the same circuit as your stereo - you could have simply roasted the clock itself.
maxfever1987
Nov 19, 2016 08:01 PM
NewMax03
Oct 29, 2015 07:44 PM
MaximaRaj
27
Oct 2, 2015 07:31 AM
zzznightmarezz
Sep 21, 2015 06:32 PM
chernandez1278
Sep 16, 2015 01:18 PM
