Malfunction indicator light on
96 maxima GXE 5 speed. Today when I drive, I found malfunction indicator light was on. The owner's manual says it may indicate a emission control problem. Does anyone know how to find the problem?
The light is always on but not blink. The light on my 96 maxima owner's manual is called malfunction indicator light. I can not find check engine light in my owner's manual. Maybe these two light are same but have different names.
0111
Diagnostic Trouble Code 0111 is detected when ...
- EVAP control system does not operate properly.
- EVAP control system has a leak in the line between intake manifold and EVAP control system pressure sensor.
Possible causes include ...
- EVAP canister purge volume control solenoid valve stuck closed.
- EVAP control system pressure sensor and its circuit.
- Loose, disconnected, or improper connection of rubber tube.
- Blocked rubber tube.
- Blocked or bent rubber tube to MAP/BARO switch solenoid valve.
- Cracked EVAP canister.
- EVAP canister purge volume control solenoid valve.
- Closed Throttle Position Switch.
fastcarny
Oct 6, 2015 10:42 AM
Maxima30
Sep 7, 2015 06:13 PM
