egr valve
Old Jun 19, 2007 | 11:18 AM
  #41
andrei3333's Avatar
Originally Posted by Dexter
there is a guide courtesy of 2da_mizzaX which helped me out alot when mine was clogged, PM me with an email and I will forward it to you (I dunno why admins don't put it in the stickies it's the most straightforward guide i've ever read)
this is very true. after u sent me the guide i was like WTF this is not in the stickies for ?
i think the only way something is stickied is if someone sends the writeup / info/ pictures to the mods !!! otherwise they just dont see it
Old Jun 20, 2007 | 07:00 PM
  #42
mlooking2's Avatar
I changed my EGR valve and EGR Tube and cleaned the block ports. But still get a code of P0400 next I will try the EGR solenoid valve..If I still get the PO400 code what will be my next step ?
Old Jun 21, 2007 | 05:09 AM
  #43
SSzretter's Avatar
Where can I get this guide by 2da_mizzaX?
Old Jun 21, 2007 | 05:23 AM
  #44
maximized98's Avatar
Addicted to the Org
I want a copy of it as well. I'm getting the 0302
Old Jun 21, 2007 | 12:17 PM
  #45
black_maxed95's Avatar
i third that, post the link up here
Old Jun 21, 2007 | 12:22 PM
  #46
andrei3333's Avatar
let me try it the easier way first:
Old Jun 21, 2007 | 01:07 PM
  #47
SSzretter's Avatar
Very cool, but if you are removing the IACV and Throttle body, do you need a replacement gasket for anything?
Old Jun 21, 2007 | 01:11 PM
  #48
andrei3333's Avatar
YES and YES, use a new gasket on the TB and the IACV - trust me on this, besides if u have the chance to replace a part and put something brand new on ur engine, why not do it ? its only a few dollars
Old Jun 22, 2007 | 05:26 AM
  #49
max ride 41's Avatar
Originally Posted by RockfordMax
yes, but its illegal for some reason and i dont know what itd do for emissions(isnt that the only reason its even there?) but i just left mine clogged, because it doesnt hurt anything or help anything,its just kind of a pita.
wrong, it exchanges hot and cold air in the engine and helps with gas mileage when not clogged. i put a new egr tube in and cleaned the intake out and my gas mileage is better and the car runs better for it. and no more check engine light. do you think it was meant to be clogged??? nope, its just build up from being so old and crappy gas leaving deposits.
Old Jun 23, 2007 | 03:28 PM
  #50
srbob000's Avatar
Just curious is the the tube that come out from the side the one that needs to be cleaned or am I cleaning the wrong one. The tube has like a bolt in one end and a rubber connection on the other one cause I have the same problem and I replaced the whole valve/solenoid. Thanks
Old Jun 23, 2007 | 09:19 PM
  #51
what????? it is an egr tube that clogs, selenoid is totally different. its got 2 bolts on one side and it connects to your intake. is'nt there pics in this thread???........( look up )
Old Jul 24, 2007 | 03:27 AM
  #52
jwl's Avatar
jwl
Another Soution to 0302 Error Code
I have an Infiniti I30 1999 and I have been getting the 0302 error code. After two visits to the mechanic, they found out that it was the clogged vacuum line, which connects to the EGR Valve, that was causing the error message. Only cost me $90.
I hope this helps.
JWL
Old Jul 24, 2007 | 09:03 AM
  #53
Sounbwoy's Avatar
There are two tubes. The MAIN tube that gets clogged is the larger one. HOWEVER, the smaller tube you speak of should be checked as well. The rubber tube that connects it can get weak over time and and actually prevent airflow, as I found out when I did mine.
There wasn't much in the tube, but I cleaned it with small piece of speaker wire and Seafoamed it, and replaced the rubber tube. It can't hurt anything to do it...
Pic
Pic II
Just as a thought, two of the pics in that picture diagram further up were taken by me. I've made my pics publc so anyone could use them. It would be nice to get some credit tho....
Old Jul 24, 2007 | 04:23 PM
  #54
andrei3333's Avatar
i got that diagram with pics from an old user i think its was cdg2125 or something like that, sorry bro
Old Jul 24, 2007 | 04:35 PM
  #55
Sounbwoy's Avatar
sigh......
Old Aug 7, 2007 | 08:10 AM
  #56
mlooking2's Avatar
I changerd my EGR solenoid valve and now the code PO400 is gone for good.Its been 2 months now.
Old Oct 15, 2007 | 01:56 PM
  #57
mystican's Avatar
I bent the bug EGR tube down til it broke right where that big a$$ nut is...the good thing is that the small egr tube is cleaned. Has anyone replaced the the big egr tube?
Old Oct 15, 2007 | 02:47 PM
  #58
Bobo's Avatar
I haven't cleaned by EGR valve or IAC valve.
Where is the EGR plenum? I understand that is what gets clogged up. Is this the tube that is being referred to?
I had to replace my EGR control solenoid last December.
Old Oct 29, 2007 | 05:16 PM
  #59
joewatch's Avatar
Code P0400 help!
Ok, I have a 1998 Nissan Maxima GXE. Got code P0400 and P0325. The mechanic replaced the EGR Valve, cleaned the EGR tubes, and replaced the knock sensor. 2 days later, P0400 comes back. The mechanic replaced the BPT Valve and EGRC solenoid. 2 days later, P0400 again.
Any thoughts? If there is something wrong with the EGR system, why does it take 2 days to throw the code? Is it possible I have a bad EGR temperature sensor? (another $100-$130 part.)
Old Nov 2, 2007 | 01:24 PM
  #60
Sounbwoy's Avatar
R U sure that the tubes were cleaned? Also, IF they did clean the tubes, but did NOT clean the back of the intake plenum where the big tube attaches at the top, then I would think there is still a clog there.
shilov
Feb 19, 2024 09:40 PM
TKHanson
Nov 24, 2018 01:39 AM
tseng1023
Oct 15, 2015 08:30 AM
hayne
Oct 5, 2015 11:53 AM
bumpypickle
Sep 19, 2015 01:07 AM
