wiring cefiro headlights
Old Nov 29, 2004 | 07:08 PM
venompwr2's Avatar
I ordered a set of Cefiro headlights (should be in this week) but I am not sure of how the wiring goes on the H4 bulbs or what bulb it takes for the corner light. Could anyone who has them help me out by telling me which wires are the ground, high and low beams on the H4? And which bulb is used for the corner light, and the same for the wiring? Thanks
Old Nov 29, 2004 | 07:38 PM
95bkackmax18s's Avatar
all i know is the corner lights stay the same and for those you just cut a away a tiny piece in the socket thing ( of the headlight it self) so the light socket it self will fit, very easy. did thet make any sense? you will see and for the new h4 harness, just splice the old wires into the new harness, i just guessed and got the first one right and took it from there.( black goes to bkack, two more and your done) when you put your lights on, just make sure lows are lows and highs are both highs and make sure you cut out what you need to, the more cutting, the better fit. thats the main thing and i had to rig up my grill, but over all, it looks great, i have a 1/4 inch gap on the corner lamp, fender part, but that will be fiberglassed the spring. good luck
Old Nov 30, 2004 | 04:22 PM
venompwr2's Avatar
Ah, I didnt know the corner light used the same socket, I figured it was a different bulb. I'd rather not try to just guess with wiring the headlights, right now I have the 9007 conversion so the wires are already changed around. I'll look around online to see which terminals are which on the H4 bulbs.
doctorpullit
Oct 28, 2019 10:58 PM
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
Noela
Sep 26, 2015 08:22 AM
