Shaved emblem peoples
Old Apr 19, 2001 | 09:46 AM
Kenneth's Avatar
OG :)
Heck, I got bored and took them off.
Yet thin adhesive remains amongst my blue paint. Can anyone spot me advice how to remove the thin flim that says MAXIMA?
Thanks in advance.
Old Apr 19, 2001 | 10:05 AM
JacksMax's Avatar
Thanks in advance.
WD40. Goo Gone. Hair dryer and fingernails?
Jack
Old Apr 19, 2001 | 10:25 AM
Kenneth's Avatar
OG :)
1.Didn't work
2.Don't have
3.Won't reach
4.Not long enough..
Old Apr 19, 2001 | 10:40 AM
jt151's Avatar
Rubbing Alcohol
Try using the white rubbing alcohol and apply it to a rag. It worked really well when I took my emblems off. It's safe on your paint, too!
Old Apr 19, 2001 | 10:41 AM
cyclemax's Avatar
Try some duct tape or other really sticky tape. Keep applying it and pulling it off. It works slowly, but I've found it to be one of the best for removing goo without scratching, etc.
BTW, put the affected area in the sun to warm it and soften the adhesive.
Good Luck!
Old Apr 19, 2001 | 11:40 AM
AGnismo's Avatar
I used Rubbing compound made by Turtle Wax to get the extra 'glue/cement' off.
Old Apr 19, 2001 | 11:51 AM
GaMax97GLE's Avatar
Emblems for sale?
Those of you with a 97-99, do you want to sell your silver MAXIMA emblem? I went to the dealership for a new one but they are expensive, so I thought I would get a used one in good condition. E-mail me if you want to. Thanks.
Old Apr 19, 2001 | 11:59 AM
JacksMax's Avatar
1.Didn't work
2.Don't have
3.Won't reach
4.Not long enough..
Perhaps you should buy some really dark sunglasses???
Jack
Old Apr 19, 2001 | 12:16 PM
Kenneth's Avatar
OG :)
Jack
I have a pair of Killer Loops, thanks though
Old Apr 19, 2001 | 12:52 PM
Autobahn Max
Use some wax...Meguire's Cleaner wax should take it off.
Old Apr 19, 2001 | 03:28 PM
_DRU_'s Avatar
i know how you feel, i debadged my car a while ago and some glue still remains. tried nearly everything...
Thanks in advance.
Old Apr 20, 2001 | 12:07 AM
Nismo's Avatar
alcohol+ credit card + heat gun
Old Apr 20, 2001 | 11:18 AM
Kenneth's Avatar
OG :)
Probably not adhesive. I tried many of these suggestions, except buffing maybe. It's etched into our paint. Texas heat!
Old Apr 20, 2001 | 12:34 PM
Nismo's Avatar
maybe you are seeing the untouched paint that was under the emblem compared to the rest of the faded paint.
Old Apr 20, 2001 | 06:47 PM
BobMax's Avatar
Four solvents to remove most anything
1. Laquer Thinner
2. Enamel Reducer
3. Wood Alcohol (rubbing alcohol may also work)
4. Body Shop type paint "prep" cleaner.
5. Acetone
Different glues are made from different bases. What removes one won't touch another... but one of these will be the one you need if it's really glue. OTOH, if your paint is faded, it won't help. Use lots of rags and lots of solvent once you find the one that works.
DON'T use rubbing or polishing compound, or so called finish restoring products. All have abrasives.
Bob
Old Apr 20, 2001 | 07:08 PM
Gotrice4's Avatar
Thanks in advance.
I went to a paint store and bought a product called "Goof gone" or off or something like that but they have alot of similar product like that at paint supply or at the paint sections at home depot and the like, worked so easily that i regret i didn't think of it earlier...
Old Apr 20, 2001 | 07:19 PM
kineshi1
Same problems
I had the same problem and had just half a M and half a X on ... two days ago i just sprayed it with wd-40 and used a dull knife and edged it off without causing any damage..my fingernails wore out by this point thus i resorted to the knife, i would suggest going straight to the knife..
Old Apr 20, 2001 | 08:10 PM
Supa Lao's Avatar
Use what Nismo said. To take off my hamburger logo, I just used WD40 and a credit card. Got all the adhesive off of the car. Save your finger nails and use a credit card
Old Apr 21, 2001 | 08:40 AM
tunedup's Avatar
bug and tar remover
will do it ...
Old Apr 21, 2001 | 11:11 PM
thebigsadler's Avatar
Re: Four solvents to remove most anything
how much do they sell the MAXIMA emblems for at Nissan?? and as for the adhesive.. i scrapped it off with my fingers and used bug-off and tar remover stuff, then just prewaxed and waxed my back end.. looks perfect.
Old Apr 22, 2001 | 01:28 AM
Riot^'s Avatar
two things
1 - I want to remove the Hamburger logo from my trunk, how do I even begin on this?
2 - If anyone got that silver MAXIMA emblem they don't need, email me pleeze! I'll take it off your hands.
Old Apr 22, 2001 | 11:56 AM
Mike'z Max
i just took the hamburger off ten minutes ago, its about 80 out and i read your post and it seemed better than doing homework. anyway, i just used a hairdryer and a credit card. i took the remaining glue off with a combination of "goo gone" ((this is the best stuff) and the hairdryer, melting the remining glue off using my fingernail and then putting the goo gone on and wiping it off. then i polished and waxed. i left the MAXIMA logo on and it looks good lined up with the chrome key hole.
mike'z max
Old Apr 22, 2001 | 12:35 PM
_DRU_'s Avatar
took off all the glue just now...
i took my emblems off right when i got my car a while ago and some glue remained. i tried everything except for the "butterknife technique" and was real skeptical of it, i thought i would do some damage. well i tried it real carefull this morning, all you do is lightly rub the rounded edge of a butterknife where the glue is and it pops right off. no scratchs or anything, nice and clean.
Old Apr 22, 2001 | 01:02 PM
AlexH's Avatar
I used wd 40 and a credit card. But for the small marks, I used toothpicks. They actually worked really well for me.
Old Apr 22, 2001 | 02:07 PM
Riot^'s Avatar
so to start...
All I need is something to warm up the hamburger and then just take it off with a credit card? sounds simple enough, or did I miss something?
Anyone has that MAXIMA logo they want to get rid off? I'll take it off your hands!
Old Apr 22, 2001 | 06:11 PM
Re: so to start...
just use dental floss to remove the emblem.. in and out motions, couldnt be any easier.. then use the hair dryer and credit card and all that non sense..
REDinLV
Aug 15, 2024 12:30 AM
litch
123
Jan 4, 2024 07:01 PM
mkaresh
Mar 12, 2018 06:48 PM
REDinLV
Sep 28, 2015 12:31 AM
