the max lost a bunch of weight today
#44
Originally Posted by sterlingmaxima
__________________
SPEED KILLS BE SAFE DRIVE A HONDA .
What a way to steal my sig, get rid of it asap !
Anyways, Id love to pics of this thing, Dont forget about the bumper supports, and I think you should take off the belt for the ac, and just completley take it off
#46
Originally Posted by 2 Da Max
my friend took out the metal plate behind the back seat. took a sawzill to get rid of the thing holding the plate. he cut out the spare tire well and placed sheet metal on it. maybe you should remove the fuel tank and get a race cell?
#52
Originally Posted by RockfordMax
what in your guys' opinoin do you think a bone stock max would run with extreme weight redux? because if i can find a decent winter car(basically a POS with heat and some traction) i think this will be my first mod, and after that start building motor and suspension. i come from a racing family, and my dad thinks im a dumbass for making a maxima race car... i wanna prove him wrong
#58
Originally Posted by plurco
man I hate getting moved. This is in response to building my NA max, but I understand that it is not actually about engine mods. I would jsut rather be there than in the land of colored LED's and body kits.
bwahaha
#59
am shooting for 2000, I think 2200 is realistic though. I have extreme plans though, why not? this is a free car.
Next year i will have 2500's with full interior including pass seat.
Dont forget to strip the wires out of the car that arent being used.
And i good hood and trunk with spoiler off my car i think will lose 70-75lb.
Brakes another spot where lots of weight can be lost i estimate 50lbs +. Remember a 2200lb car does not need 11 inch rotors anymore ,huge overkill.Once i get my car in the 2500's smaller rotors are going on with half as light caliphers. Are calipers are like 8lbs a piece. I can save 16-20lbs with just lighter caliphers.
#60
Originally Posted by JSutter
i really dont remember the glass being close to 10 lbs. but if you say so i believe you.
#66
#71
Originally Posted by madmax96
i have a mag. with a 96 max in it and it has all the insides and it says it weights in at 2800lbs runs 12.1 with 150 shot 2 stage and on slicks and also automatic
Jime
#73
I have done some weight reduction but I am no where near the level of Krismax. If it is a drag only car you don't need anything. For those that don't think A/C doesn't weigh much, your forgetting something. The Evap box under the glovebox weighs a good 5Ibs. Get that outa there. Also, if your not worried about control power steering is worth several HP/TQ and all told it probably weighs 30Ibs. The steering bump stops on the spindles are worth 3Ibs. Rear brakes aren't really needed although I don't know if you'll pass tech check in.
You can sell all the stuff you've removed and use that money for CF lid and hood.
-Sunroof and rail(25+Ibs)
-Exhaust after y-pipe.(40+Ibs)
-Keyless entry brain(1Ib)
-Antannae if retracting type.(4Ibs)
-Extra cooling lines to TB and EGR.
-Cooling lines to heater core.
-Heater Core
-Entire Dash(I mean everything. You don't need any gauges besides Tach and if your good you don't even need that.)
-Sound deadening
-FSB
-Splash Gaurds.(Wheel well too)
-All interior obviously
-Y-Pipe(9 Ibs)
-Splash Guard(2 Ibs)
-EGR stuff
-Hoodliner(1 Ibs)
-Stock Drivers Seatbelt Assembly(5 Ibs)
-Racing Bucket(18Ibs)
-Brake Rotor Dustsheilds(9 Ibs)
-UDP(3 Ibs)
-Stock Intake Plumbing(4 Ibs)
-Wall Behind Rear Seats(6 Ibs)
-Exhaust Heat Sheilding(9 Ibs)
-Plastic Guard Around Brake and Gas Lines(1 Ib)
-Removed Dash Bar(2 Ibs)
-Misc. Bolts and Brackets(3 Ibs)
-Removed Rear Tow Hooks(2 Ibs)
-Secondary Exhaust Bracket(1 Ibs)
-Passenger Side Tow Hook(1Ib)
-Stock Foglight Brackets(1.5Ibs)
-Windsheild Washer Stuff
-Cruise Control(3Ibs)
-Plate Under Steering Wheel(2Ibs)
-UDP(3Ibs)
-Jack and Mounting Bracket(7Ibs)
-Spare(28Ibs)
-A/C(35Ibs)
NPM just started a great new project. http://nissanperformancemag.com/december04/g20_racecar/
Keep going. I'd like to know what true race weight is. Once you determine the weight we can start making guesses at e.t/trap. The basic rule of thumb is crude but still... If your goal is 2000Ibs then you'll be in mid to high 13's. But we must remember weight vs. traction is a direct relationship.
-Heater Core
-Sound deadening
-FSB
-Y-Pipe(9 Ibs)
-EGR stuff
-Hoodliner(1 Ibs)
-UDP(3 Ibs)
-UDP(3Ibs)
-Spare(28Ibs)
-A/C(35Ibs)
#74
Hey Im at work right now but i have had this done for almost two years I will get the belt size tomarrow and just PM me and I will PM you back with the belt size, by the way if you are going to by pass it you may as well just take it off extra weight if it doesnt work anyway.
Bruce
Bruce
#75
yea i had my car stripped forever, no back seats, nothing in the trunk, no carpet, everything that is not needed in the engine bay was out, including the a/c, and yea it did run like a beats but it was just uncomfortable.....so everything is back in for the winter.
when i stripped my car i had everything out.....
i didn't have....
-A/C....lines, condenser, comperssor,.....everything baiscally.
-no back seats
-no carpet
-the whole trunk was stripped
-no center council
-no glove compartment
-everything in the engine bay was out that was not needed, no girll, battery in the trunk, only the CAI, and i could pretty much stand in the engine bay.
I did have.....
-y pipe
-no back muffler just the stock b pipe,
-place racing motor mounts
-CAI
-NX kit
-cf hood and lip
and some other lil small things, i was light as hell and the car was quick as fucc, and very responsive
i didn't have....
-no back seats
-no carpet
-no center council
I did have.....
-y pipe
-CAI
-NX kit
-cf hood and lip
#79
Originally Posted by Broaner
Any updates on all this? I'd love to see the full race Maxima acutally come to fruition.
