audio, remote key stop working
Old Dec 4, 2004 | 06:00 PM
tian's Avatar
help! audio stops working (all fuses are good)
the audio and remote control stopped working on the same day. after reprogramming the remote control, it works now. but the whole audio (bose) is dead, radio and cd player totoally inoperative, not a single light is on. checked all the fuses in interior fuse box and engine compartment fuse box. all are good. any idea what i should do? thanks a lot!
Old Dec 4, 2004 | 09:50 PM
sunten1
if you get an airbag light sign in the dash its your alternator........along with your brake light
Old Dec 4, 2004 | 11:36 PM
tian's Avatar
no, i didn't see the airbag warning. and all the lights are working well.
Old Dec 5, 2004 | 12:44 AM
Iilac's Avatar
Spelled with a I not a L for Iilac. Prounced Ii-eee-ack.
Check the ELEC fuse that is in the cabin fuse box. It is in the top right corner. I believe on the diagram where it shows where all the fuses correspond to, it says ELEC on a white /black background.
Old Dec 5, 2004 | 10:09 AM
tian's Avatar
the fuses are good. I checked every fuse and fusible link just now, both the interior fuse box, and the fuse box in the engine compartment. nothing wrong. however, the cd trapped inside ejected when i was checking that fuse you mentioned.
Old Dec 5, 2004 | 10:13 AM
Akumachan's Avatar
I never narc'd on nobody.
correct me if im wrong, but the remote gets its signla through the radio's antenna, right? so clearly theres a problem wit the entire radio system. and the HU wont even power up, just nothing happens? odd... all i can say is try to check as much of the wiring as you can.
Old Dec 5, 2004 | 12:25 PM
tian's Avatar
now the remote control works again after reprogramming. (i think the remote control receiver should be something separate from radio.) yes, the whole headunit is dead.
ah2002
Mar 9, 2016 01:42 PM
jerrod99_se-l
Aug 27, 2015 08:27 PM
Shock_and_Awe
Aug 23, 2015 01:02 PM
MidnightMaxima_22
Aug 19, 2015 01:01 PM
kenc15
Aug 5, 2015 08:29 AM
