Limited Slip Differential
Or.. Jack the front end of your car up, both tires off the ground, rotate one tire and watch the other tire, if they spin in the same direction then u do, if not then you dont.
All U.S. 4th gen 5 spd's did not come with LSD.
5spd I30's did
Canadian 5spd's did also.
5spd I30's did
Ok...is there not a sticky about this???
Anyways, pop your hood, look on the left side on the firewall. You'll see a bunch of engraved codes, one will be your tranny code. If it has a V in it you have LSD. Otherwise no. And if you don't, I think you'll have an A in it.
James92SE
142
Jan 2, 2024 09:23 AM
Pied
Sep 26, 2015 03:29 PM
