threw some codes
Old Dec 5, 2004 | 11:01 PM
Maximeltman's Avatar
threw some codes 0304 0512
0304-KS
0512-downstream O2 sesor high voltage fault
what can I do, replace the o2 sensor, rplace the KS, or both?
I also may be in need of a fuel filter change, I dont know the last time that was done. This im thinking could trip the KS code, but not entirely sure.
anyone got some input?
Old Dec 6, 2004 | 12:35 AM
chenzarino's Avatar
I'm suffering from 0902 - Downstream oxygen sensor heater or circuit fault myself. From what I hear a bad Downstream sensor kills gas mileage, so i'm looking to replace it myself.
Old Dec 17, 2004 | 01:14 AM
bump
cmon guys please help lol
Old Dec 17, 2004 | 01:17 AM
Ant96GLE's Avatar
Change the 02 first then reset the ECU.. see if the KS code comes back up.
Old Dec 18, 2004 | 10:24 PM
isnt the ks a ghost code? meaning if i change the o2 sensor only, will it be hidden? not to sound dumb, but is there a way to actually tell is the ks is bad, like a certain resistor-reading on a DMM or something?
Old Dec 19, 2004 | 04:57 AM
Ant96GLE's Avatar
NOt always, I just changed my knock sensor yesterday and my CEL finally went away.
Old Dec 19, 2004 | 05:45 AM
MilesA's Avatar
Yes, you can check resistance of the KS with a DMM. The wiring harness has two terminals. Resistance between the left terminal and ground should be in the range of 500-620 Kohms at 77 F.
The FSM has a procedure for diagnosing the KS code, this is only a part of it.
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
