ECU Code 10:01 is it bad to drive while lights on?
Old Dec 6, 2004 | 06:43 AM
BORQUA79's Avatar
nycmaximas member
Well, I recently replaced my Y-Pipe/Cat/Bipe/Muffler and a couple weeks later I got the code 10:01... I read that its the left O2 sensor heater...
Is it bad for the engine to drive with that code for a few more day until I get the part and change it myself?
What exactly does that sensor do and what problems might arise?
Should I bother the mechanic that installed the set-up? I mean It worked fine before I changed the parts... Could he have broken it?
I hear something about running lean with that bad O2 sensor. What would running lean do that would harm the engine?
Im just concerned... I hate that yellow light...
-Alex
Old Jan 13, 2005 | 05:39 PM
kchida's Avatar
BUMP.
I have the same problem, wondering the same thing. Anyone know?
Thx
Old Jan 13, 2005 | 05:43 PM
Ant96GLE's Avatar
Your not going to run lean, its probably going to trip the Knock Sensor and the engine will run in safe mode. Change the sensor, if you need a used one, I have one I took off my car in good condition, I'll give it to you dirty cheap. They are very easy to change...
Old Jan 13, 2005 | 06:57 PM
I30tMikeD's Avatar
It won't hurt anything nor will it cause the car to run in safe mod even if it causes a knock sensor code to be thrown. Nealoc187 had bad o2 sensors while he ran a 13.4 NA and his turbo car does not even have the sensors at all
Old Jan 13, 2005 | 09:52 PM
Ant96GLE's Avatar
On a side note, I've driven my car for 2 years with a bad 02 sensor and CEL... its a very long story
kjlouis
Nov 24, 2018 06:09 AM
homeyclaus
Sep 3, 2015 06:15 PM
doobadoo
Aug 15, 2015 06:43 PM
yat70458
Aug 3, 2015 01:16 PM
maxima297
Aug 3, 2015 12:50 PM
