Need help. ecu code 0111.
Old Dec 8, 2004 | 07:08 AM
dzw's Avatar
dzw
http://memimage.cardomain.net/member...035_3_full.jpg
I got the code 0111. Diagnostic Trouble Code 0111 is detected when ...
- EVAP control system does not operate properly.
- EVAP control system has a leak in the line between intake manifold and EVAP control system pressure sensor.
I have checked the car. The part in the picture does not work properly. It is black plastic box with 3 hoses attached on it. It allows the fuel vapor get into engin to burn. Normally the vapor can not flow between each hose. Only when the thin hose get vacuum, the vapor can flow betwen the two thick hoses. If it does not work properly, the fuel vapor will leak and the car will have a bad gas milage. Anyone knows the name of it and where I can order it?
Old Dec 8, 2004 | 07:48 AM
knight71's Avatar
From the stickies:
0111
Possible causes include ...
- EVAP canister purge volume control solenoid valve stuck closed.
- EVAP control system pressure sensor and its circuit.
- Loose, disconnected, or improper connection of rubber tube.
- Blocked rubber tube.
- Blocked or bent rubber tube to MAP/BARO switch solenoid valve.
- Cracked EVAP canister.
- EVAP canister purge volume control solenoid valve.
- Closed Throttle Position Switch.
- Improper connection of one-way valve.
- Blocked purge port.
- EVAP canister vent control valve.
This is a "jackpot" code. It points to so many possible causes as to be almost useless. It may be accompanied by another DTC which is more specific.
Old Dec 8, 2004 | 07:51 AM
knight71's Avatar
Also:
http://members.dslextreme.com/users/...esm/a32-ec.pdf
Old Dec 8, 2004 | 01:03 PM
dzw's Avatar
dzw
Originally Posted by knight71
Great book. It has a detailed description. Thanks you so much. I found the name is EVAP canister purge control valve.
gigabyte
Jan 6, 2017 06:05 PM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
