Help....
Help....
I got a 96 maxima GLE. When it is cold, it starts up perfectly, but takes about 10 minutes for the heating to come on. Is there a way I can get the heat to come on faster... It starts blowing right away, but its cold air... Please help... Thanks in advance
Does your engine take a while to heat up? Or is it that your heater doesn't kick in enough for you?
If you car takes a good while to heat up, then its your thermostat. If its your heater, then you heater coil is probably going bad.
Its just not warmed up yet. Look at the temp guage. You can turn on the car before you leave. I also turn off the heat until it's warmed up. Don't know if this really speeds things up or not though.
jasba
Jul 16, 2005 08:18 PM
lalaMAX
Detailing
Jul 3, 2005 05:42 AM
