sway bar question
Old Dec 8, 2004 | 02:59 PM
PKaiser's Avatar
sway bar question
is there a big difference between the progress rear sway bar and the stillin rear sway bar?
Old Dec 8, 2004 | 03:04 PM
Akumachan's Avatar
I never narc'd on nobody.
price is about it
Old Dec 8, 2004 | 03:09 PM
MaximaSE96's Avatar
Maxima Owner
Originally Posted by Akumachan
price is about it
i hear that.,,,,if ur lowered or on any kind of stiffer suspension ponder the thought of OVERSTEER.....cause u will get alot if u have already updated ur suspension
Old Dec 8, 2004 | 03:12 PM
Akumachan's Avatar
RSB is really only helpful when you keep stock suspension right? cuz the max is a bloody 4x4 on stock springs, so you gotta reduce body roll any way you can. thats what im getting out of all this atleast, i could be wrong though.
Old Dec 8, 2004 | 03:14 PM
PKaiser's Avatar
maybe in a max, everyother car ive been in thats not true. many of myfriends have good suspensions, then bought sway bars and got even better performance.
Old Dec 8, 2004 | 03:15 PM
MaximaSE96's Avatar
Maxima Owner
our rear suspension sux i want my 3rd gen rear suspension.....but on our cars usually the RSB on modded suspension is more PITA than helpful...lke i said unless u like oversteer
Old Dec 8, 2004 | 03:18 PM
Ant96GLE's Avatar
Not just price... the Stillen is adjustable and prettier
but then again so is the progress and addco, all you have to do is move the bushings in and out more.
Old Dec 8, 2004 | 03:20 PM
Akumachan's Avatar
could be better than understeer, which im currently fighting... correct me if im wrong, but on a fwd car, oversteer is gonna be a lot easier to correct than on a rwd car, so oversteer sounds downright pleasant to me.
Old Dec 8, 2004 | 03:23 PM
MaximaSE96's Avatar
Maxima Owner
but it can also be too much
Old Dec 8, 2004 | 03:29 PM
Akumachan's Avatar
yeah, tis a delicate ballance between good and evil...
Old Dec 8, 2004 | 03:40 PM
PKaiser's Avatar
have any of u experienced the oversteer cause by the sway bar, because ive never heard of this, especially in a FWD.
i always thought if you dont put your struts to the stiffest setting, and dont push the bushings too far out on the sway bar you should be fine.
Old Dec 8, 2004 | 06:35 PM
vsamoylov
what about the cattman sway bar?
Old Dec 8, 2004 | 06:45 PM
Maximus_Brayan's Avatar
cattman is just a rebadged progress sway bar
Old Dec 8, 2004 | 06:46 PM
Ant96GLE's Avatar
Since when does Cattman make their own products
Cattman relables Progress sway bars.
Old Dec 8, 2004 | 06:58 PM
vsamoylov
wow i never knew that
what about the cattman fsb then?
also what is the difference and is there one with having a adjustable rsb?
and anybody have a link for the progress sway bar. i want to know how much it runs casue i am looking for one myself.
Old Dec 9, 2004 | 11:17 AM
drewm's Avatar
http://maxmods.dyndns.org/index.php?MaximaSwayBars
Old Dec 9, 2004 | 12:23 PM
BEJAY1's Avatar
Conecarver
Yep. Granted I don't take corners at the limit above 50-65mph but I still can't get the rear to step out. 450lb springs rear, stiffened struts, 205 rear rubber, RSTB, RSB full stiff, no FSB, trail braking, etc. Maybe I'm too smooth a driver but I doubt it.
http://forums.maxima.org/showpost.ph...9&postcount=26
Old Dec 9, 2004 | 02:38 PM
PKaiser's Avatar
i think we just have a bunch of talkers on this board, ive never heard of a rsb causing understeer, sounds like driver error to me. I guess ill find out for sure soon tho.
Old Dec 9, 2004 | 04:00 PM
90EightSE's Avatar
When I added the Progress RSB to my '98 with stock springs, and KYB agx the first thing I noticed was less sway of course and then a tendency towards oversteer but I did not find this to be a bad thing. When I cornered hard around a deserted corner, as I whipped the steering wheel to the right the rear came around and straightened out the path of the car. I had to turn the wheel back to center quickly but all this made for what I consider a more controllable turn. Before the RSB doing the same maneuver would result in lots of body roll with little or no oversteer. I haven't tried this maneuver since adding a RSTB and lowering my car because I'm still learning the new handling characteristics and don't want any unexpected surprises until I have put more miles on the setup but I don't see how the tendency to oversteer could possible go down.
Old Dec 9, 2004 | 04:40 PM
chipobrien's Avatar
I added the Stillen RSB to an already lowered (1.5 F&R, Tokiko's and Stillen FSB) and noticed an improvement immediately on a sweeping left turn on I-287N to I-78W in NJ. It was worth 7-10 MPH on that curve (from about 60 MPH to 70+ MPH), you know, a "comfortable" type thing, no white knuckles.
Some mechanics that have driven my car ('99 GXE, comparing it to an '01 SE) are amazed at the handling. (Both are 5 speeds, the SE is stock.) Their words, not mine. As to which bar is better, don't know. I may be mistaken, but the GXE doesn't have a stock RSB, but doesn't the SE?
Old Dec 9, 2004 | 05:16 PM
The SE doesn't have a rsb
Old Dec 10, 2004 | 04:55 AM
BEJAY1's Avatar
Conecarver
Sure it does. What are you driving?
Old Dec 16, 2004 | 03:52 PM
VQuick's Avatar
Chassis Freak
Are you sure? I know there is a front anti-sway bar stock but I think the multi-link beam setup in the rear is the only "anti-sway" bar that the Maxima comes with. If I'm wrong, please give me a reference that proves it.
Old Dec 16, 2004 | 04:03 PM
Ant96GLE's Avatar
Our cars do have a rear sway bar... take a look at the rear beam, it has a gap under neath and the stock rear sway bar is in there.
Old Dec 16, 2004 | 04:21 PM
VQuick's Avatar
Chassis Freak
Ah, so it's up under the U-shaped beam. Learn something every day. Sorry I doubted.
Old Dec 16, 2004 | 04:22 PM
Ant96GLE's Avatar
I never knew we had one either till i saw a pic of it here somewhere
gman214
Sep 25, 2015 03:03 PM
zzznightmarezz
Sep 21, 2015 06:32 PM
ColdCananda
Sep 20, 2015 10:45 PM
Stagnet04
Sep 14, 2015 11:28 PM
