anything wrong with driving with a bad cat?
Old Apr 20, 2001 | 03:21 PM
sachin98max's Avatar
my random technologies cat went bad about 3 weeks ago, but don't have the money right now (college student) to throw around about $70-$80 to put my stock one back on, return the random cat at my expense, then get my new random cat (as no charge of course), and install the new cat. i was wondering if im losing anything by doing this?? is it bad for any part of my car...or am i losing any power?? from what I know, i think i'll be fine as long as i don't have my inspection comin anytime soon. but thought i'd ask some of the more mechanically inclined to help me out with this. thanks in advance.
sachin
Old Apr 20, 2001 | 06:15 PM
Chunger's Avatar
My other car is a Hybrid
Definitely lose power and if it gets bad enuf... you'll get reversion into your intake...
Old Apr 20, 2001 | 06:51 PM
Dan 93 SE's Avatar
Bad Cat.
If your Cat went bad, it did so for a reason. I suspect you have engine problems. Check out our web address, there is a section that deals with why Cats go bad. We have sold several that peopple want to return but are unable to, becuase the engine wrecked them. They should last a LONG time. If your new Random Tech cat went bad, correct the problem before trying a new cat or you will probably wreck the new one as well.WarpSpeedPerformance.com
Dan WSP
Old Apr 20, 2001 | 07:12 PM
Damn i wasn't aware of this.....it's a lot bigger of a deal than i thought it would be. man now im scared that somethings wrong with my engine. dan..thanks for the info from your website...im goin to check it out right now. chunger...thanks for ur input also. i guess i'll be doin this tomorrow then. thanks again.
sachin
Old Apr 21, 2001 | 07:02 AM
Daniel B. Martin's Avatar
Please elaborate
I don't know what this means. I want to learn more. Reversion of what? Please elaborate.
Old Apr 21, 2001 | 09:37 AM
Ramius83
What, Daniel B. Martin doesn't know what reversion into the intake is? Oh my, what is this world coming to. Everyone knows what that is
Old Apr 21, 2001 | 10:17 AM
Chunger's Avatar
Re: Please elaborate
When the catalytic gets bad enuf it starts to collapse causing a restriction in the exhaust system... This in turn allows blow back from the combustion camber back into the intake system where you'll start to see carbon build up in the intake manifold or even further upstream if it's bad enough.
Old Apr 21, 2001 | 10:52 AM
ionicmax's Avatar
Former Sponsor
Have you gone through any deep puddles??
I had a cat go out on me because I went trough a deep puddle of water. If you haven't gone through any deep puddles then you might have some engine trouble.
Old Apr 21, 2001 | 12:39 PM
Chunger's Avatar
Re: Have you gone through any deep puddles??
I think you had some bad luck there... I would think it wouldn't be typical of the catalyst block to separate from the wall just by going thru a puddle...
Old Apr 21, 2001 | 06:44 PM
got rice?'s Avatar
Re: Re: Please elaborate
That's not reversion, though. That's just plain 'ol backpressure. Reversion is on turbo vehicles - when the throttle plates are closed, the pressurized air hits the throttle plates and reverberates back towards the turbine housing/compressor wheel if it is not vented out or recirculated through the system.. hence blow off valves or recirculation valves.
Old Apr 21, 2001 | 07:08 PM
Chunger's Avatar
Re: Re: Re: Please elaborate
I thought it was whenever you have 'backflow' (like the Chikaru header ads) but I STAND CORRECTED...hehe
Lakersallday24
Nov 7, 2024 07:31 PM
JRod28
Dec 29, 2023 09:56 PM
kjlouis
Nov 24, 2018 06:09 AM
homeyclaus
Sep 3, 2015 06:15 PM
FlaMark
25
Aug 28, 2015 10:15 AM
