hazzard and defrost switch problem
Old Dec 14, 2004 | 01:47 PM
sterlingmaxima's Avatar
okay i need some help i need some one with some expertice in these switches I just did teh led mods awhile ago, I got a new hazrad switch i just can figure out how the darn thing clicks in it will blink the lights if i push it in but as soon as i let go they stop i know somebody knows how to fix this any help would be aperciated
Old Dec 14, 2004 | 02:06 PM
Igobuk's Avatar
Inside the hazard switch is a spring, a tiny pin and a small triangular shaped piece. If you look at the triangle, it has two grooves in it where the pin is supposed to ride in perpendicular. Do not lay down the pin in this grooves, it goes standing up. The pin however is suppose to be inside of a small hole on the other portion of the switch.
So, place the pin in the hole where it belongs.
Place the trangle where it belongs and make sure the grooves are visible, not face down.
Now carefully put it together so that the pin will end up riding inside these grooves.
Don't forget the spring and the switch should work.
I had the same problem at first and it was because I had not put the pin into the grooves so the button wouldn't "click".
Good luck.
Old Dec 14, 2004 | 02:28 PM
okay man just got it thanks alot
Old Dec 14, 2004 | 04:37 PM
Igobuk's Avatar
Outstanding. Glad to help.
Mar 12, 2020 12:06 AM
rnb754
Sep 14, 2015 11:39 PM
Maxie40
Sep 14, 2015 11:28 AM
