Changing a Starter need advice
Old Dec 16, 2004 | 02:26 PM
maxima2fly's Avatar
am changing the starter i need help i bought a starter it says i gotta hange starter relay tat came with nissan? do i have to do thise ?
Old Dec 16, 2004 | 02:31 PM
NmexMAX's Avatar
dot dot dot ...
Umm, I don't really understand what you said, but I got mine from Autozone, and it was direct replacement, straight foward approach, connect everything that was on the old started, on the new one.
Old Dec 16, 2004 | 04:01 PM
apbrian112's Avatar
^^^ did the same... i didn't have to change any relays or anything it was just 2 bolts and unplug the sensor. then reattach everything and bolt it down. re-install the intake and you should be good.
Old Dec 16, 2004 | 04:54 PM
maxima2fly's Avatar
i got like a technical support intructions when i got with my starter it says WARNING~~ the most common reason for starter failure is the starter realay nissan part-25230-c9962, thise must be replaced as well failure to do so may result in the following conditions
-starter jus clicks
-Starter continues running when the key is in off position
-tapping on the starter solenoid to startthe vehicle
-Starter grinds or makes noise
So what should i do ? replace thise or wut? by the way i got no mechanic experience but i think i can manage doing thise i have change brakes and did a tune up lol so jus tell me is thise a job i can do ?
Old Dec 16, 2004 | 08:22 PM
Supa Lao's Avatar
I just replaced the starter when I did mine. It wasn't too bad of a job. I didn't replace any relays
mikeg75
Nov 30, 2015 05:12 PM
RWCreative
Sep 21, 2015 11:01 AM
rnb754
Sep 14, 2015 11:39 PM
jwright36
Sep 8, 2015 11:45 AM
