Power Steering FLuid, Windshield Washer Fluid, and Fuel Injector questions
Hello,
I need to add some more power steering fluid to my Maxima and I went to Wal Mart to purchase the Dexron. I know that Dexron is transmission fluid also. I looked in the power steering section did not find any Dexron. Went to the Transmission Fluid and found 3 WITH Dexron present. There was Valvoline and Pensoil which both had Dexron 3/Mercon. And then there was an off brand that just had Dexron.
- Which do I get, or are none of these what I need?
2) Also for Windshield Washer Fluid, I saw some windsheield Washer that was de-icer as well, can I mix that with the current blue washer fluid in the car now?
3) Also what type of fuel injector should I add. I heard it should include techron. There was some up there for cold starts as well... can I use both?
I would appreciate any responses ASAP so I can go purchase the items ASAP
Thanks again
Thanks again
You should use ATF that complies with Dextron II or above in the power steering system.
You want windshield washer fluid with de-icer in it. You can mix it with what is there.
If you need fuel injector cleaner, get the Chevron brand with Techron. It is a black bottle. You don't really need anything else. And you only need to use it occasionally, like the last tank before you change the oil. If you can put Chevron premium fuel in the tank regularly it already has Techron in it, so you might not need to add any.
i posted in the fluid/lubricant thread. They said it's ok to use Valvoline Synpower PS fluid. I'm still iffy though because it doesn't say Dexron III on the label. I've had it for 500 miles now, no problems. I don't know. anyone have any other input
Read the stickies.....
1. Power Steering Fluid will say just that on the bottle, while Transmission Fluid will advertise itself as "transmission fluid." Do not put Tranny fluid in the power steering resovoir. I don't know what all this dexron business is about... I'm confused as to whether you're asking about tranny fluid or power steering.
2. Mix it up all you like - de-ice, re-ice, whatever. It seems like a waste of time and effort to drain out the leftover washer fluid before pouring in the new stuff because it's not the exact same.
3. Techron is a trademark of Chevron, so you'll only see that name on their bottles. I've heard nothing bad about it, but is it something special? I couldn't tell ya - maybe it is, maybe it's not. Just stick with name brands - not the Wal-Mart brand injector cleaner - Chevron is fine. I would NOT recommend dumping all kinds of cleaners and boosters into your tank at the same time, though. Cold start stuff may contain silicon - good for preventing freezing in the lines, but it may cause unwanted deposits in the system. It's your call....
Originally Posted by SolidSnake
...1. Power Steering Fluid will say just that on the bottle, while Transmission Fluid will advertise itself as "transmission fluid." Do not put Tranny fluid in the power steering resovoir. I don't know what all this dexron business is about... I'm confused as to whether you're asking about tranny fluid or power steering.
3. Techron is a trademark of Chevron, so you'll only see that name on their bottles. I've heard nothing bad about it, but is it something special?..
1. The Factory Service Manual for our cars says:
Originally Posted by FSM
Recommended fluid is Automatic Transmission fluid type "Dexron II" or equivalent.
3. Techron is one of the only fuel injector cleaners that has been found effective by the SAE. Most of the others have not demonstrated their effectiveness.
I agree with you that mixing a bunch of fuel additives together is a waste. Most fuel additives are snake oil, anyway.
Originally Posted by lokobreed
Dexron is what Maxima recoomends, I dont know if its a brand
And it's not a brand, just a trademarked formula - Valvoline, Castrol, Pennzoil, etc all advertise their tranny fluids as being a Dexron tranny fluid.
hey
http://www.valvoline.com/pages/produ....asp?Product=6
or
http://www.valvoline.com/pages/produ...asp?Product=64
-- Is either of these what I should get for my power steering?
It has Dexron 3 and says ATF but also has Mercon, what is that? I cant find one with just Dexron 3
Or this penzoil one
http://www.pennzoil.com/products/trans_fluids/dex3.html
or
Or this penzoil one
Dexron and Mercon are not ingredients.
If the fluid meets Dexron-III, then it also meets Dexron-II. You can use it in your power steering!
or
or
For steering fluid, get something like this:
http://www.valvoline.com/pages/produ...asp?product=30
And what does your quote from the FSM reference? Is that talking about what to use for tranny fluid or power steering fluid?
please last questions
So I can use any of the above?
-- Which is best penzoil's or Valvolines?
Also if I have some power steering left in the resevoir do I need to empty it or can I just top it off?
--- Also the fluid in there currently is light blue, I thought ATF fluid (Dexron) was dark?
Really? Power steering will operate with any oil in it?
Loko, either of them is fine as long as they meet the specification. Pick the one that is the best deal or the one that has the prettiest label.
I edited the older post just a minute ago!
Sorry, SolidSnake, I didn't see your question before. That reference from the FSM is in the Power Steering section. It's true you can buy fluid that is marked specifically for power steering, but that's what the FSM calls for.
thanks
thanks milesa
/\ What about that /\
All I'm saying is that the manufacturer recommends to use ATF of type Dexron-II in the power steering system. Fluids that meet the Dexron-III specification will meet or exceed the Dexron-II specification.
Forget what I said, newbie! I learned just as much as you did here. I should hang my head for adding to the misinformation of our forums
Loko, if you go to www.motorvate.ca, there is a write-up in there for changing the power steering fluid. If you want change it, just follow that.
Hey
Thanks for the info...
But what Im trying to figure out is, can I just add that new Dexron Fluid on top pf what Power Steering fluid is in there now?
Or do I need to change it if I do not know what type is in there now?
If the new fluid meets or exceeds Dexron-II, then it is compatible with the fluid that's already in there.
The manufacturer does not specify that you have to change power steering fluid. But if you want to change it, you can. Just folllow the write-up on www.motorvate.ca.
I'm surprised you haven't asked this question: "Why do I need to add power steering fluid?"
lol
LOL
I was just afraid that if the fluid currently in the car (since I bought this car used) was not ATF Dexron 3, if it was just regular PS fluid, that I couldnt just put the ATF DExron 3 on top of that, but your saying I can no matter whats in there currently right?
vingodine
45
May 21, 2016 12:46 PM
Mrbizness1
Aug 18, 2015 08:43 PM
scarletsosa
Aug 17, 2015 09:09 PM
jchronis2552
Aug 13, 2015 07:48 AM
