View Poll Results: Do you adjust your Illuminas at all?
Yes
57.14%
No
42.86%
Voters: 21. You may not vote on this poll
Illumina Adjustments
Old Dec 17, 2004 | 12:38 PM
oTranscendental's Avatar
How many of you guys actually adjust your illuminas? I leave mine on 5 hardest all the time.
What about you?
Old Dec 17, 2004 | 12:49 PM
NetFurie's Avatar
I adjusted mine continously for the first month I had them. Since then, I changed the rears from 4 to 3 and the fronts from 3 to 2 because of the cold weather.
Old Dec 17, 2004 | 12:58 PM
Seximus Maximus's Avatar
Keep mine on 3front/4rear. but like the above post im going to change to a softer 2/3 cause its so damn cold.
Old Dec 17, 2004 | 01:34 PM
Y2KSESteve's Avatar
I change mine for the track only. Normally I run at 2/4 or 2/5
Old Dec 17, 2004 | 01:49 PM
MaximaTodd's Avatar
G
just changed mine for the winter to 1/2. i'm more for the comfort in the winter than performance. summer time i run 2/3.
Old Dec 17, 2004 | 02:11 PM
fadeaway's Avatar
Go Hokies!!
I'm a stiffy at 5/5 all the time so far.. I don't really mind the solid ride. I tried 2/2 for a couple days a little while ago, but I went back to the stuffness.
Old Dec 17, 2004 | 06:19 PM
njmaxseltd's Avatar
On long highway trips sometimes I go full soft for that caddy like ride.
Normal every day driving I'm set at 3f/2r.
2f/2r is a nice smooth ride too.
I'm running H&R springs.
Old Dec 17, 2004 | 06:45 PM
Why are you guys changing your settings for winter? Is it more stressful on the shocks?
I actually wish my shocks were even stiffer. When I had them installed, I thought they were on three, but to my surprise, they were already on 5!
Old Dec 17, 2004 | 06:51 PM
drewm's Avatar
You and me both, I wish my rear Konis had more compression dampening, rebound is set perfectly, but compression could use a higher setting. Fronts are perfect. I'm set at full stiff on Eibachs.
Old Dec 17, 2004 | 07:31 PM
PLUMMAXSE's Avatar
I've settled on 2/2 with H&R springs. I ran 1/2 for a while and I lost control of the front end. Too vague of a feeling! Everything changes the way the car feels on that setting. Even a full tank of gas.
I think soft in the winter and stiffer in the summer is the ticket.
Old Dec 17, 2004 | 09:13 PM
MilesA's Avatar
In winter the shocks+struts become stiffer when the fluid inside them gets cold and doesn't flow as easily. So to get equivalent stiffness, you can dial the setting down a notch. Plus it's nice to have a little softer ride for when the roads are rougher with snow and ice.
Old Dec 19, 2004 | 10:35 PM
bluestealz's Avatar
Jacked Up off MountainDew
i have illuminas, but didnt install them yet....was wondering how easy it is to actually change the settings?
Old Dec 19, 2004 | 11:20 PM
MilesA's Avatar
It is pretty easy. Once you have done it a time or two, you can probably do it in five minutes or less for all four. You really don't have to adjust them very often once you find a setting you like, either. Just the seasonal thing.
Old Dec 21, 2004 | 06:05 PM
PLUMMAXSE's Avatar
Man,
How did you do that? Takes me 5 minutes to get the liner out of the trunk and them 5 minutes to do all 4 struts.
Old Dec 22, 2004 | 02:48 PM
MilesA's Avatar
Originally Posted by PLUMMAXSE
Man,
You don't have to actually remove the trunk liner, you can just peel it back from each side over the wheel well. That way, the main part of the liner stays in place.
Old Dec 24, 2004 | 06:56 PM
gto400no1's Avatar
i used to adjust them a lot when i first got them, but then i had to put my trunk back together and my system back in. now i dont, even though i want to adjust the backs i am just too lazy to unhook my system and all that. right now i am at 2/3, and its not bad but i want to try 2/4 and 3/4 and eliminate a little bit of the bounce in the back of the car.
Old Dec 26, 2004 | 12:35 AM
ThurzNite's Avatar
5/5 all the time. The roads I travel on aren't too bad. And if it is bad, I'm scared of bottoming out so I slow down anyways. Oh yeah, I'm on Sprints.
Jae
Old Dec 26, 2004 | 08:15 AM
THT's Avatar
THT
Throbbing member
I run 2/3 and leave it at that. Good combination of performance and comfort.
~THT
Old Dec 27, 2004 | 03:12 PM
michaelnyden's Avatar
so what would be the best setting paired with eibach springs?
Old Dec 27, 2004 | 04:50 PM
i30ds's Avatar
Armed and Dangerous
3f/4r here! That set up really helps out with the horrible stock understeer.
I don't know how some of you guys can take 5/5, it is stiff as hell!!
tarun900
19
Dec 20, 2021 06:57 PM
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
leatherneck
Sep 30, 2015 09:16 PM
