Downstream Oxygen Sensor
Old Dec 17, 2004 | 02:51 PM
caudio51's Avatar
So I got these two diagnostic codes today, read up on them in my Haynes manual but I was looking for a more generalized explanation
0707 Downstream Oxygen sensor or circuit fallout
0510 Downstream Oxygen sensor maximum voltage monitor fallout
From what I have read the downstream sensor has no effect on the PCM air/fuel ratio. The rear sensor should produce a lower voltage due to the lower amount of oxygen present at that point.
I am guessing that there may be a bad connection since there is a signal problem.
Since I have a DTC it is now running on an open loop fuel control.
What I am a not fully understanding is the troubleshooting from this point.
Any info would be great!
Old Dec 17, 2004 | 03:45 PM
MDeezy's Avatar
if you have a multi meter you can read and see if the sensor is outputing the amount it should be, since you got a code for that sensor, it seems as though its faulty and you'll need to replace it? are you trying to diagnost and make sure that its truely bad or that is really is bad?
Correct me if I'm wrong but I thought the rear o2 plays a less important roll once car is warmed up, but until then is just as important as the other 2 o2?
Old Dec 18, 2004 | 10:24 AM
caudio51's Avatar
youre right about the warming up part partially. The car does not use any O2 sensors until 600F is reached. And the rear o2 sensor is not as important as the front ones.
Old Dec 18, 2004 | 02:01 PM
MaximaSE96's Avatar
Maxima Owner
its jsut like the pre-cats in a stock y-pipe....useless after main cat is hot
Old Dec 19, 2004 | 09:25 AM
MAXRB8's Avatar
You think you have rear o2 problems! Check out this guy!
http://forums.maxima.org/showthread.php?t=363241
Old Dec 19, 2004 | 11:33 AM
caudio51's Avatar
ha thats certainly bigger than my problem
TallTom
57
Oct 14, 2025 05:16 PM
my03maxima
Jul 28, 2024 07:40 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
