Destroyed Antenae
Old Dec 17, 2004 | 06:43 PM
phathead's Avatar
Destroyed Antenae
it got broken off in the citgo car wash... it was a power one, i was just wondering what i need and how much it should cost to di? thank you
Old Dec 17, 2004 | 08:02 PM
z32drifter's Avatar
you just need the mast.... you may have to buy it from the dealer.... easy to replace.. just remove the nut on the top of the ant shaft... remove the old parts and turn the radio on..... feed the new mast into the shaft and have someone turn the radio off... the motor should catch the teeth on the cable and pull the ant in.... replace the nut on the shaft and your done.... oh yea rember to turn the radio off in the car wash
Old Dec 17, 2004 | 08:05 PM
Bigwalt304's Avatar
heres a how to with pics http://www.carstereohelp.org/DoItYou...ssanPwrAnt.htm
BigLou93SE's Avatar
That didn't work for me -- I have to go to a stereo place to get it out. For some reason or another, the original mast is stuck in the antannae motor housing. Anyways, it doesn't hurt to try, but the solution may be more difficult than what z32 had said.
by the way, I think that it may have been tampered with, because my cable was taken out of the antennae, allowing it not to move up and down.
Old Dec 17, 2004 | 08:23 PM
z32drifter's Avatar
if the cable is broken or missing.... you may have to remove the ant motor assy and take it apart to remove the broken part left inside the gear set... and with any car type repair you may experience abnormal problems.... but normally when they get snapped off in the car wash you can replace they easily
Old Dec 17, 2004 | 10:49 PM
SlackR237's Avatar
Rollin' on 'Caps
I had the same exact thing happen to me, and try as I might, I couldn't for the LIFE of me get that mast out of the antenna motor.
I ended up just getting an entire OEM antenna motor from eBay, installation was simple, just put the antenna motor back in, connect two wires, plug in the grommet and you're all set.
It works great now
jmlee44
Oct 2, 2022 02:13 PM
fx4five
Oct 18, 2015 06:57 PM
fx4five
Oct 1, 2015 04:58 AM
Maximeltman
Sep 28, 2015 07:19 PM
msellas
Sep 23, 2015 09:16 PM
