fuel meter light
Old Dec 18, 2004 | 01:42 PM
konak85's Avatar
fuel meter light
The low fuel indicator light on my '96 max doesn't work anymore. How can i fix it? New Fuse?
Old Dec 18, 2004 | 01:45 PM
MDeezy's Avatar
I believe all the lights in the guages run off of the same fuse so if a fuse was blown your guages wouldnt light up at all, could be the light is out, I think (dont know for sure) its a led so you'd need to desolder and replace.
just speculating.
Old Dec 18, 2004 | 03:02 PM
MDeezy's Avatar
here is a pic of the back of the tachometer, hopefully this helps.
may just be a matter of taking out the cluster seeing what type of bulb/led and replacing.
Old Dec 18, 2004 | 03:24 PM
MaximaSE96's Avatar
Maxima Owner
i broke my trim piece taking my cluster out..........i suck
Old Dec 18, 2004 | 03:48 PM
SHADETREE95's Avatar
I noticed mine doesn't work either so I pulled out sending unit and jumped the little cylinder on the bottom of the unit and my light came right on. So I know my sending unit has a bad part I think you have to change the whole sender you can't just solder a new one on there to get the light to work again.
Old Dec 18, 2004 | 04:12 PM
Ant96GLE's Avatar
Change the bulb
Old Dec 18, 2004 | 04:17 PM
Wills98MaxSE's Avatar
1 of few unmodded 4G Maxs
Originally Posted by Ant96GLE
Change the bulb
and try not to let your tank get that low either
Old Dec 18, 2004 | 04:38 PM
Ant96GLE's Avatar
Very true, especially now in the winter... its not a good idea to let your tank get that low.
Old Dec 18, 2004 | 04:44 PM
Conrad283's Avatar
I need a truck
I always count my mils per tank. So even in my needle is at 1/4 and my trip is at 300 I know it's time to fill up real soon.
mvm062
Nov 30, 2020 09:00 AM
BkGreen97
Apr 2, 2016 05:47 AM
aminus21
Sep 12, 2015 04:53 PM
Maxima30
Sep 7, 2015 06:13 PM
