Rattle solutions...post them here..
Old Apr 21, 2001 | 07:30 PM
SWEETSOUND2001's Avatar
Anyone that has had or has any rattles on the inside of their max...Post the rattles you have/had and how you have solved them. Also, if you haven't solved them just tell us where they are coming from. Hopefully a lot of you guys will reply so we will be able to use this post as a sort of reference for rattle solution..
Mine:
A-pillar rubbing against dashboard..
Solution: Put rubber or cloth between the bottom of the pillar and the dash. There is a little gap that you can use.
Old Apr 21, 2001 | 10:25 PM
GarthG's Avatar
I am looking to get rid of these rattles:
One coming from passenger side of the dash, somewhere near the airbag occuring at speeds ~70 MPH+
Upper to middle part of the A-piller when bass hits. . . I don't know how to remove it to get any silencing material behind it.
Old Apr 21, 2001 | 11:46 PM
Demo's Avatar
Rear Strut
That was my prob....take off the pannels in the trunk and the rubber caps on the strut towers inside the trunk. Hop in (yes, the trunk) and get a trusted partner in crime to drive around on some bumps (anywhere in northern ontario will do)if You see that center nut knocking anywhere get a set of vice grips and a box end wrench and tighten it some
Old Apr 21, 2001 | 11:55 PM
edward079
oops, shoulda posted here! 99 SE Tweeter rattle (both)
Old Apr 22, 2001 | 06:00 AM
deezo's Avatar
[QUOTE]Originally posted by SWEETSOUND2001
[B]Anyone that has had or has any rattles on the inside of their max...Post the rattles you have/had and how you have solved them. Also, if you haven't solved them just tell us where they are coming from. Hopefully a lot of you guys will reply so we will be able to use this post as a sort of reference for rattle solution..
I am looking to do quiet the noises down in my Max also. I was thinking I would fill the corner panels with some foam. I know for sure that the defroster air vents on the dash makes noise when hitting bumps.
Old Apr 23, 2001 | 06:34 PM
Justin95SE's Avatar
yah i think my defroster vents rattle too. nm
nm
user 11122324
42
Jul 18, 2022 03:35 PM
lrb6805
Sep 17, 2015 04:49 PM
jerrod99_se-l
Sep 16, 2015 02:39 AM
thenewguyy
Sep 12, 2015 11:12 AM
NissanNismoZ
Sep 12, 2015 07:30 AM
