got viynl paint, spraying dash this week
Old Dec 22, 2004 | 04:10 PM
exit10's Avatar
my car is in the shop getting the front tire fixed as you all know got messed up in my snow drifting accident. but as soon as its out i am painting the entire dash n stuff black.
my question is should i just cover everything w/ newspaper and then spray? or is there a way to take off the dash. ( im talking about the ENTIRE thing closest to the windshield).
i have tan leather and plan to paint everything black but the seats and headliner and any fabrics. i hope it will look good compared to the doodie brown current color.
any ideas?
Old Dec 22, 2004 | 05:59 PM
jdm71488's Avatar
take your time and do it right... i just painted my dash trim graphite, it looks pretty good... but im going back to stock soon... it looks quality since i took my time, and yours will look good too if you take yours...
my .02
Old Dec 22, 2004 | 06:45 PM
Irish's Avatar
This is a democracy
take off the dash other wise you probably screw it up and end up painting the windsheild costing you more money, like jdm71488 said, take your time and do it right, or when it comes out screwed up dont biatch on here
Old Dec 22, 2004 | 09:26 PM
95nissanMax's Avatar
for sure take out ur dash and then paint everything. ask euromax about paiting your interior he did the best job by far on the org.
Old Dec 23, 2004 | 11:41 AM
exit10's Avatar
is that in the stickies? i didnt see how to acutally take out the viyln part closest to the windshield.
Old Dec 23, 2004 | 11:57 AM
MDeezy's Avatar
if you have a haynes manual they have a section in there that shows how to take out the entire dash board.
I'd take it all out so you can have much more space to paint each piece, plus you dont want to be in the car panting and the fumes getting to you.
post some pics when you get done.
Old Dec 23, 2004 | 02:55 PM
exit10's Avatar
aite!, i am going to tackle this job over the weekend with my friend who is doin his ford explorer. i will post as soon as its done... (if your lucky i will do a detailed write up)
Old Dec 23, 2004 | 03:44 PM
Longboarderphil
dont do it it will crack and flake off in a year. I hada body shop do it to my DSM with spray dye and it cracked after about a year. and its not that they didnt do a good job its that, its not a very good adhesion substance. I would learn how to fiberglass and then have it painted. Fiberglassing over a dash is easy. In fact that what i did to the dsm after the dye started to crack and flake. if u need to know how to glass hit me up on aim its really easy, just time consuming.
Old Dec 24, 2004 | 03:45 PM
exit10's Avatar
i started spraying the door panels today and it looks absolutly terrible. i dont know what to do now. i think i am going to take some paint thiner to it... AHHHHHH
Old Dec 24, 2004 | 07:05 PM
MDeezy's Avatar
daaaamn, did you sand it all down properly?
what does it look like? can you still see the tan underneath.
dont forget that you'll need to put about 4-6 coats of paint to get a good look, and you must let each coat dry before applying the nestone. plus does you paint have gloss in it? if not then it will look flat and crappy till you get some gloss in it, or apply some clear coat to give it a shine and good finish.
Old Dec 24, 2004 | 07:15 PM
2 Da Max's Avatar
put some clear coat when your done. but all the vinyl paint i have seen has faded so far.
Old Dec 25, 2004 | 07:03 AM
Zirafa's Avatar
I spray-painted my airbag cover 2 years ago and it still looks good. I also painted the entire dash in another car about 1.5 years ago using the same spray-paint and it still looks good. The paint I used is SEM vinyl spray-paint and I bought it at NAPA.
There are two important things you must do to make it look good - first, prep the suface,; I used fine grain sand paper and alcohol to prep/clean the surface; second, spray in very thin coats (fine mist rahter than spray) and try not to overlay too much, leave it about 20-30 mins to dry and repeat this 4-5 times or until you get the desired look. You must be patient; otherwise it will look like crap.
Old Dec 25, 2004 | 12:37 PM
SE95MaxSkyline's Avatar
anybody in the NJ area i may have a black dash no airbags and 97 center console forsale for $300 and i will install the dashboard for them if purchased thats only if my friend ends up buying my car from me through the insurance (totaled my car) but i use to have tan interior and i did the swap by myself my dash is already out took me 25 mins to take it out sooooo easy well iv3e done 3 swaps already so its kinda quick for me but email me if intreseted civic93hbgsr@aol.com
doctorpullit
Apr 23, 2017 05:35 AM
Kingofmaximas24
Nov 12, 2015 04:40 PM
Luigi623
Sep 21, 2015 01:42 PM
BrandonCause
Sep 20, 2015 10:20 PM
bumpypickle
Sep 19, 2015 01:07 AM
