Radiator Leak
Old Dec 23, 2004 | 12:12 PM
Vlasic's Avatar
RaWr!!! ('''_(o_O)_''')
Radiator Leak
i have a very small leak on the top of my radiator about 3 inches to the right of the cap. when i look t it really closely there is a litlte bit of air seaping out and i can see some bubbles. like i said...it is a REALLY small leak. is this something i can patch up with epoxy or something else?
Old Dec 23, 2004 | 02:49 PM
SHADETREE95's Avatar
If it is small enough and you can get at it you might be able to solder it.
Old Dec 23, 2004 | 03:36 PM
Vlasic's Avatar
the crack is right on the top on the plastic part. your saying just take a soldering iron and melt it shut?
Old Dec 23, 2004 | 03:40 PM
No I don't think that will work on plastic I thought it was in the metal part. I guess you could try some plastic epoxy then.
Old Dec 24, 2004 | 12:27 AM
izzydig's Avatar
replace the little bastard. Once the radiator starts leaking, well, watch for more leaks once u patch it.
I've tried before, using something with steel in the name of it, and I patched one hole, and a week later another hole developed. After patching the second hole, another hole developed.
Plastic gets weak and brittle over time and heat.
Old Dec 24, 2004 | 09:04 AM
MDeezy's Avatar
the old myth actually works, crack an egg in there and it should plug it up.
of course I dont rely on that as a permenant fix but it can stop the leak.
( I'm sure you guys wont like that idea)
Old Dec 24, 2004 | 11:16 AM
jackiss2888's Avatar
Wow, I had the exact same problem. I tried some JBWeld, which didn't bond very well and after a week, the hole punctured through it. I just got a new one from Autozone for $170. If you plan on having the car for a but, I would suggest gettign a new one beofre antifreeze starts spraying all over your motor.
Old Dec 24, 2004 | 11:35 AM
Vlasic's Avatar
ive been having so many problems lately that i dont want to keep the car, but i really dont have any other choice. guess ill just buy one form kragen or something.
Old Dec 24, 2004 | 11:44 AM
Ant96GLE's Avatar
Get a new radiator, if you were here in NYC I'd literally give you one I have laying around for dirt...
Its very easy to replace and any type of JB Weld or epoxy is only temporary
Old Dec 24, 2004 | 11:55 AM
Vlasic's Avatar
i just PMed a local 4th gen guy who usually has lots of parts laying around. if that fails ill probobly just get a Koyo one off ebay.
litch
123
Jan 4, 2024 07:01 PM
user 11122324
42
Jul 18, 2022 03:35 PM
aw11power
Oct 10, 2021 04:57 AM
Miket2006
Mar 1, 2021 03:55 AM
Unclejunebug
Apr 2, 2016 05:42 AM
