hoses coming off the intake?
Old 12-26-2004 | 02:59 PM
guyfromkop's Avatar
what size are these hoses coming off the midpipe? and what exactly do they do? and if i'm making a midpipe, what kind of sealant can i use around the hose attachments?
Old 12-26-2004 | 03:55 PM
Vlasic's Avatar
RaWr!!! ('''_(o_O)_''')
the hose in the front coming from the right side of the engine is an exhaust hose that just shoots the air back into the intake (i believe) but you dont need it as long as you put a small filter on the end of the engie after you take off that hose. the other you need to keep. you dont need any sealer just clamp them on using the existing metal spring clamps.
Old 12-26-2004 | 04:19 PM
guyfromkop's Avatar
but what size hose is it?
Old 12-26-2004 | 05:31 PM
kcryan's Avatar
sorry how many hoses total are there and can i use RTV sealent to make a gasket between my MAF and its adapter?
Old 12-26-2004 | 07:51 PM
Vlasic's Avatar
what size hose? how many hoses? come on guys go open your hood and find out. i dont know where you guys are getting the idea for sealant. i have never needed to use any sealent on my intake for the hoses or the conectors. everything goes together with bolts or the screw down ties.
Old 12-26-2004 | 08:01 PM
kcryan's Avatar
sorry i need some sort of sealant cause the cheap kit i got has some holes and parts that dont fit perfect
Old 12-26-2004 | 08:12 PM
JSutter's Avatar
I'm nutty for Nissans
front valve cover hose is slighty smaller than the IACV hose. I dont remember the sizes off the top of my head. Then there is one small vacuum hose. thats all. when i made a mid pipe i used JB weld to seal and hold the hose fittings to the tube.
Old 12-26-2004 | 09:31 PM
zachosz's Avatar
i THINK one is 3/8, the other 1/2
Old 12-26-2004 | 09:41 PM
Paradox Cefiro
^ Bingo...
Old 12-27-2004 | 09:28 AM
kcryan's Avatar
so there are two larger ones and one small one?
95Maxi
08-29-2015 10:38 PM
MAXSE5SPD
08-23-2015 01:06 PM
MaximaDrvr
08-19-2015 09:20 PM
scarletsosa
08-17-2015 10:09 PM
acw
08-07-2015 05:20 PM
