what the hell is wrong with my starter?
Old Dec 27, 2004 | 12:27 AM
bignick's Avatar
Went to crank the car tonight and it cranked for 2 seconds, the just died and now all I hear is a whirring sound from the starter. Figured it was just the starter going, but now I'm wondering if its beyond that - when I cranked it, the car lurched forward a tiny big with the e-brake on (96, 5 speed), even though the clutch was all the way to the floor; even with the key out of the ignition, the thing is still spinning.
Its not really cranking, just whirring really loud and won't stop until I take off the neg. battery cable. I don't know where to start - anyone else have an issue like this? What I think -
-Ignition switch (since its still spinning even with the key out)
-Flywheel issue (since the car jumped forward, even though the clutch was down).
-Need a new starter (or is that less likely since even its activated with the key out).
-Relays - which should I test out as being stuck open?
Old Dec 27, 2004 | 12:29 AM
96nismomaxi's Avatar
.org window licker
aighty first go out there and take the terminal off the starter and see if it is still makeing that noise
Old Dec 27, 2004 | 08:07 AM
BrentK7's Avatar
starter cylinoid stuck in the ingaged position perhaps?
Old Dec 27, 2004 | 08:10 AM
max_speed97's Avatar
our starters are known to be bad....i had this problem also on my 97 auto...needed to get new one....give maximum tuning a call in LI (Jeff) he helped me out...
Old Dec 27, 2004 | 05:35 PM
bignick's Avatar
Thanks for the tips... Took it apart and the gears were shredded(!) and the solenoid was stuck open. Got a new Bosch with lifetime replacement (even if they suck, it took me 20 minutes to take out/put in) and its fine.
BobTX10
Oct 7, 2015 08:43 AM
RealityCheck
Oct 2, 2015 06:34 PM
bigfrank
Oct 1, 2015 12:51 PM
maxima297
Sep 30, 2015 03:32 PM
