Need Help!!!!! Clutch Or Tranny
Old Dec 27, 2004 | 10:28 AM
well known tone's Avatar
car revs up but doesnt pick up
need info on what the problem might be, car revs but doesnt pick up like it used to, it does move but i dont know if it is a clutch issue or a transmission problem... 95 manual.
Old Dec 27, 2004 | 11:46 AM
How Do You Know When You Need Either A New Clutch Or A Transmission Is Going Bad. What Are The Differences?
Old Dec 27, 2004 | 11:47 AM
DR-Max's Avatar
Sounds like the clutch is slipping badly, you probably need a new clutch.
Old Dec 27, 2004 | 11:50 AM
Jeff92se's Avatar
I'm needing a caw
Take care of your auto problems in one post thanks. And please take the time to use the caps function correctly. It will help in getting a proper reply.
Old Dec 27, 2004 | 11:58 AM
MDeezy's Avatar
slipping clutch, I would get it checked out, how many miles on the clutch? could be an old clutch, or if its pretty new maybe your tranny is leaking oil on it causing massive slippage.
Old Dec 28, 2004 | 06:14 AM
mu_max's Avatar
I would think it is the clutch. My tranny went out and before it did it made a loud whirring noise when the clutch was out, and the noise dissipated when the clutch was pushed in. Good luck
Old Dec 28, 2004 | 06:19 AM
BigLou93SE's Avatar
That would be a bad throw out bearing...yea, it sounds like you've got a slipping clutch. To check -- get in 2nd, 3rd, or 4th gear, get on a steady speed, then floor it. Watch your rpm's though, and if the engine revs do not match the speed at which you're traveling/accelerating, you're clutch is slipping. Try not to drive hard on the bad clutch, as it will eat up your flywheel if you let it wear down too much. Get it checked out soon.
user 11122324
42
Jul 18, 2022 03:35 PM
spencerwh1
Jun 30, 2016 05:44 AM
fx4five
Oct 18, 2015 06:57 PM
fx4five
Oct 1, 2015 04:58 AM
Socalstillen
Sep 20, 2015 11:46 PM
