Different types of Clear Corners???
Ive been lookin around on this site and i have noticed something about the clears but im not sure...some of them look different from others...am i right on this??? can someone pls post some pics of different types of the clear corners available for the max???
There are two types that I know of . One is basically a Euro corner but the design is exactly like the stock corner signal lense except for the fact that it's white. There is also one that has a diamond cut pattern on it, and this in my opinion looks a lot better , and it also reflects light differently.
Diamond Cut clears
Also, it takes about 15 minutes to put these in. I do have some recommendations for some steps to make for a better installation which I'm going to post on my website soon.
1 more vote, get the Diamond Cut clears. Much better looking IMO. Paid $52 shipped. Another cool thing about the diamonds is the effect of the amber bulbs against the diamond clear lenses. At night w/just the park lights on, the side park lamps give a cool looking glow that bleeds into the front turn signal part of the clears. Nice effect.
I have the standard clears that came out before the diamonds...they WERE nice until the diamonds came out. I would prefer to upgrade. The indicator lenses are basically clear but don't offer a whole lot of light dispersion. The diamond cut looks like it allows more places for the light to reflect, because of the way the lenses are "cut". Correct me if I'm wrong but the standard clears look really simple compared to the diamonds.
Re: Condensation???
what about condensation in the diamond cut??? any problems???
corner lighting installation tips
Also, whats so hard about installin clear corners??? Gary95...what do u recommend before installin them??? please post on ur website and let us know...
thanks
thanks
First, the OEM turn signal unit has an excellent anti-moisture control rubber tube connected to it. This tube is controlled with an insert that keeps spiders out, allows moisture to dry up, and keeps water from getting in. The replacement corners come with a very cheap plastic tube that probably keeps the water out fairly well, but will allow bugs to nest inside.
Second, the replacements don't fit VERY tightly. Enough to stay in over rough bumps, but I was a bit nervous anyway. So, I bought a roll of adhesive backed rubber insulation (Home Depot) and used this as a packing material to help make the fit snug. Worked like a charm.
Third, it is helpful to replace the existing plastic fitting with the new ones -- these accept the hex "nub" that holds the parking light unit in. You want this to be a tight fit. In the FAQ, there is some instruction on pulling back the fender guard and mounting this from the back--this makes it very difficult for a would-be thief to steal your lights. One problem though: A thief won't realize why it is so tight and will probably end up breaking the unit and damaging the bumper fittings. Personally, I'm not will to spend so much extra time on doing it--looked like more trouble than it's worth.
That's about it... hope you find it helpful.
Re: corner lighting installation tips
Originally posted by Gary95
Nothing hard, just some tips I acquired in doing it.
But one quick note: It probably won't fit very snug. What I did was purchase a tube clamp from Home Depot and put this on to ensure that it fits nice and tight. 1/2" size will do.
Whew--I feel better already.
Theres actually 3 types, cuz I own 2 of them
Theres the first gen regular clears, im guessing courtesy, tho theyre all made in Taiwan anyways. They're orange backed, and if youre about 4ft or closer you can see the orange outlines.
The next gen courtesy set are grey plastic backed, and they dont have the outline thing. (I have a black car, so orange sticks out a lil)
And the third, ill go with the diamond cut clears. Since my headlights look like theyre yellowing, forget that stuff.
As for installs, i used plumbers tape? The lil white rubberish tape? its like $1 per roll..
Re: Pics and also pricing
someone show us a shot of this diamond cut lenses and also the cheapest price i can get on it (for further buying)
If you want to see what they look like, check out PROCARPARTS.com. BTW, they are the ones that are auctioning them on Ebay too. Much cheaper to buy ($51 w/shipping) then "directly" from them at their internet site ($79 PLUS Shipping). You might have to bid a couple of times but keep at it and you'll eventually win. The advice I was given was, don't bid over $55. Worked for me.
Sorry I don't have a picture I can post....no digital camera...I'd rather buy MAX parts and mods
But you'll see quite a difference in the pics that Procar posts. Believe me, they are sweet looking. BTW, mine are made in Taiwan, and have a grey housing. So far no leaks etc. I also waited to get mine and did all the fog light rewire/blinker rewire and corner rewire at one time. Easy.Cheers
Apr 16, 2020 05:15 AM
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
