ECU Light Going Off??
Old Dec 30, 2004 | 06:49 AM
caudio51's Avatar
My ECU light went on about 2-3 weeks ago...I checked the codeds and it was my rear o2 sensor. I haven't had time to fix it so I have left it alone. Last night as I was driving I noticed the light was now off. Does the light go off after a certain period of time? Now I do not know if I should replace the o2 sensor or not.
Old Dec 30, 2004 | 07:30 AM
SUM41GIRLIE's Avatar
Yes it does that. It's going into the cycle mode, basically it's re-testing everything to see if there are other problems and if the problem you have, has been fixed. You will see it come back on in a day or 2. I heard it takes so many start up or miles driven for the ecu to cycle through all the test. I've had my check engine light on for over a year now with a code of the evap canister vent control valve. Had Nissan fix everything possible related to that code, still wont go off but it has gone off for a day or 2 now and then so it can cycle.
Old Dec 30, 2004 | 07:39 AM
caudio51's Avatar
ahhh ok thanks for the heads up....guess I still have to go pick up that sensor
Old Dec 30, 2004 | 07:54 PM
caudio51's Avatar
yup you were right on...light came back on....should have written down the mileage and counted number of starts to see what the cycle is
Old Jan 4, 2005 | 12:34 PM
Yeah belive me I am becoming a expert with that darn check engine light coming on and off. I have so many problems with my Max its unbeliveable
mvm062
Nov 30, 2020 09:00 AM
ballerchris510
Sep 10, 2015 09:35 PM
Maxima30
Sep 7, 2015 06:13 PM
mix master
Sep 4, 2015 05:50 PM
