severe front-end shaking and jerky acceleration after new plugs and fuel filter
Old Dec 31, 2004 | 12:04 PM
josehernandez94's Avatar
Yesterday (12/30) I got new platinum spark plugs and and a fuel filter on my '99 GXE, which is at 61,000 miles.
I didn't notice anything unusual yesterday, though I didn't drive around too much. Today, the front end of the car has been shaking really, really hard when it's idling (hard enough that I can feel my seat shaking). Also, when I accelerate from idle, it's pretty jerky and it almost feels as if the car's about to stall out.
I've read some posts about typical explanations for this, such as bad knock sensors or maybe even a PCV valve, but those explanations don't make sense to me, simply because this problem absolutely came out of left field, although just about immediately after I had this work done on it.
Anybody have any ideas what's going on?
Old Dec 31, 2004 | 03:22 PM
nitromax's Avatar
recheck all of the connections at the coils, check for any hoses that may have been knocked off or broken. i hope you didn,t drop & damage a plug or get a bad one. you did check the plug gap even though they're preset, just to be sure. not sure what effect a filter install wrong would have (flow direction).
Old Dec 31, 2004 | 03:27 PM
Mr.Duck's Avatar
its your coils... damn 99's i had the same problem, i had just installed my y-pipe and turned on engine to test, and my entire car was shakeing... pulled each coil out, and found the culprit, replaced the coil, and voila im running fine :P good luck!
Old Dec 31, 2004 | 08:42 PM
2stock95maxima's Avatar
if its not a ignition wire, try checking ur motor mounts , the plastic might b cracked
Excalibur23
Oct 13, 2015 04:33 PM
JoshG
51
Sep 21, 2015 10:41 PM
bumpypickle
Sep 20, 2015 08:22 AM
Bonka
Sep 14, 2015 11:18 PM
aminus21
Sep 12, 2015 04:53 PM
